SR71 treated RM30s have landed
0 Members and 1 Guest are viewing this topic. Read 8055 times.
John Casler
« Reply #20 on: 29 Jul 2005, 03:04 pm »
Sorry, I didn't see this question.
Since I am on Verizon, I never get the little e-mails that tell you when someone posts to your threads, so I have to "catch" them.
But anyhow....Ding, Ding, DIng....
Yes, it is exactly that.
It makes a very nice improvement to the RM30's.
The more adventurous could try a DIY upgrade by contacting Andre at e-speaker.com for BlackHole-5, or check Parts Express for their "Sonic Barrier"
JoshK
« Reply #21 on: 29 Jul 2005, 03:08 pm »
Actually, I would log onto silentsource.com and source "Whispermat".  It is more or less the same as BH5 or Sonic Barrier but a lot less expensive.  I used a bunch on my RM40s when I was doing the upgrades and it was a nice addition.
CornellAlum
« Reply #22 on: 3 Aug 2005, 03:36 pm »
Would this be a viable option for my 626r's?  I would like to give it a whirl.  That said, if I am going to do this, I want it to be the best option.  Which would work the best, bh5, whispermat, sonic barrier, etc?
Kind of slow around here lately :nono:  :lol:
Daryan
JoshK
« Reply #23 on: 3 Aug 2005, 04:03 pm »
Quote from: CornellAlum
Daryan
6 in one, half a dozen in the other.  Check out the BH5 vs. whispermat comparison on zaphaudio.com.  I have strong reason to believe that WM is the OEM for sonic barrier and they are in fact the same thing.
CornellAlum
« Reply #24 on: 3 Aug 2005, 04:27 pm »
Thanks Josh,
I likeyour reasoning...especially with it being much cheaper.  Would the benefit to the 626r's be the same as for the rm30/40 etc
JoshK
« Reply #25 on: 3 Aug 2005, 04:31 pm »
yeah it should be just as beneficial.
John Casler
« Reply #26 on: 7 Aug 2005, 08:21 pm »
For you DIY'ers you need to line the inside of the cabinet with either:
1) Black Hole 5
2) Sonic Barrier
3) Whispermat
Black Hole can be purchased through E-speaker (tell Andre John from VMPS sent you)
http://www.e-speakers.com/products/blackhole5.html
Sonic Barrier can be purchased through Parts Express
http://www.partsexpress.com/pe/showdetl.cfm&DID=7&Partnumber=260-535
WhisperMat through Silent Source.  Whispermat2 looks to be the most similar with multiple layers.
http://www.silentsource.com/barriers-whispermat1and2.html
This product is good for mains and subs.
I can't offer any installation tips, since I haven't done a DIY on anything yet, except cover as much of the internal sufaces as possible with particular attention paid to the inside walls opposing the bass drivers and all corners.
