Repainting the NX-Oticas
« on: 26 Aug 2026, 06:53 pm »
Luckily I now have a fair bit of experience painting after the death march that was the Line Force build a year ago.  Now I'm looking at the NX-Oticas in my HT and I realize they are too white for the HT room:
I'm planning to paint them a very dark charcoal grey instead.  Since they are already finished, it should be a very easy job - scuff sand the perfect finish, clean it, wipe it down and then spray on the new color.  Anything I'm missing?  Or other tips?
Huskerbryce
Re: Repainting the NX-Oticas
« Reply #1 on: 26 Aug 2026, 07:49 pm »
What I typically do while painting is keep my expectations insanely low.  That way, no matter how it turns out, I am happy with it.  Hope that advice helps.  I loathe speaker finishing.
nlitworld
« Reply #2 on: 26 Aug 2026, 08:16 pm »
Hey Tyson, I got you covered for all the steps you will need. First things first, do a quick solvent test on the existing paint to see what you're working with. Especially if you're going automotive grade materials, you'll need to know if the foundation is stable or if you'll have big bada boom problems. I'd suggest a little acetone rag and rub a small spot. If it completely lifts color, we have problems but if it only slightly pulls a little residue we should be stable. This evening I'll type out some basic step-by-step details on what prep I would be doing if taking on that project. Also if you want me to get a materials list of what you'd need I can easily do that as well.
Friends don't let friends make shifty looking speakers.  :lol:
« Reply #3 on: 26 Aug 2026, 09:14 pm »
I was hoping you'd chime in  8)
It might be a week or 2 before I can get some space at the warehouse to do the work, but I want to be prepared before that happens.
A materials list would be great.
The main thing I am going for is 1, very dark (but not black) and 2, not very reflective.  Because the JVC NX-7 projector I have down there is a freaking light cannon and I'm trying to get the least amount of reflection/washout possible from the speakers.  But I don't want it to look like a chalkboard, either  :lol:
nlitworld
« Reply #4 on: 26 Aug 2026, 09:25 pm »
That's totally do-able. What you're looking for is satin gloss. Long term durability is slightly compromised by comparison, and you can't buff out any imperfections, but we can work with that.
If I remember right you had a spray gun for your line forces, correct? Send me the info on that and I can gear materials around it.
« Reply #5 on: 26 Aug 2026, 09:44 pm »
This is my gun - https://www.amazon.com/dp/B01I5W00KE?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_3
I have access to an air compressor at the warehouse so that should be all set.
I was talking to ChatGPT and it recommended Benjamin Moore Scuff-X Matte because the matte finish is at 9.5 gloss units at 60°.  It's also explicitly rated for wood, is scuff-resistant/washable, and can be sprayed.
goggle1824
« Reply #6 on: 26 Aug 2026, 10:51 pm »
Oh NEAT, a repaint! I’m totally going to be following this!
nlitworld
« Reply #7 on: 27 Aug 2026, 02:35 am »
Really comes down to what you're comfortable with cost wise, expectations of finish and long term durability. Having just walked someone on Reddit through the pitfalls of a wonky BM paint and how to fix it, let me get you materials list before you jump down the wrong rabbit hole. Then you can at least make an informed decision on what's best for your setup, especially given your color choice.
nlitworld
« Reply #8 on: 27 Aug 2026, 06:19 am »
Ok Tyson, here is your recommended instruction, depending the outcome of your solvent test. If everything is good and stable, here is your repaint process for your type of color change. Sorry it's a little wordy, just like to be thorough.
For starters, sand speaker with ~400g sandpaper. Can be on a DA sander or by hand. MKe sure it is fully uniform scratched but don't dig in on the corners. Last thing we need is big cut-throughs in the no-no corner zones.
Chase sanding scratches with gray scotchbrite pads. This step puts little micro scratches inside the sandpaper scratches. Make sure everything is uniform dull finish. Make sure to tuck back in the nooks and crannies on the backside.
Wipe with wax and grease remover and dry THOROUGHLY with a clean dry rag. Work in small sections to be sure solvent does not dry on the panel. Very bad things happen if wax and grease remover dries on the panel. After that, chase panel with tack rag before sealer.
Using your gun with the 1.5mm nozzle, apply one consistent closed coat of gray or black sealer. Keep spray gun material turned down a little bit so you don't get runs.
Let sealer flash off for 30-60 minutes. If you have small imperfections like dust or texture, let sealer flash off fully, then lightly sand imperfection with 800g sandpaper in single direction strokes and allow to flash again. Don't rush that extra flash time as urethane sealer can wrinkle if rushing too fast.
Lightly wipe with tack rag to keep any dust off the surface.
With the 1.3mm nozzle on your gun, apply charcoal basecoat in probably 3 medium coats. Keep consistent distance and application speed to avoid streaky and blotchy color. Also make sure you're doing probably 75% overlap of each pass back and forth. Make sure your basecoat flashes for probably 10min between coats but goes uniformly matte before spraying next coat.
Once you're done with that, let your basecoat sit for about an hour before clearcoat.
For clearcoat, mix your clear and hardener to appropriate satin gloss mix ratio. Fully flat (matte) clear of 0-10% gloss will appear chalkboard flat. Satin gloss will be 20-30% which will give a low luster but still look smooth and consistent, and color correct. Given what you mentioned earlier, satin would be my recommendation.
So, once you mix your clearcoat, apply one wet coat with a very tight overlap to eliminate streaking. With low gloss finishes, you must wait for clearcoat to flash off and become uniformly matte before applying your second coat. Most likely 10-20min between coats. If you apply your next coat with the first still a little splotchy appearance, you will make it forever shiny and inconsistent. But let the first coat flash smooth and flat, apply a second coat exactly the same, and walk away. Don't touch it, don't look at it funny, don't call it dirty names for at least a few hours. Keep the fans blowing across it the whole time to help it set consistently. If everything comes out clean eith no hugs, dust or smudges, pat yourself on the back. Give it at least 24-48hrs before reassembling drivers back in.
I'll message you a materials quote in just a few.
« Reply #9 on: 27 Aug 2026, 05:49 pm »
I've changed my mind on the color.  Instead of dark charcoal I want to go black.  As inky, dark black as possible.  Here's why:
You can see that the sides of the speakers just light up the room with that super bright JVC projector.
Does that change anything in the steps you laid out above?
nlitworld
« Reply #10 on: 27 Aug 2026, 06:06 pm »
Wow you weren't kidding about the blinding projector lighting.
But yeah that would be pretty easy swapping charcoal for black. We could go full base/clear satin black to maximize appearance and longevity, but a good 90% shortcut would be using the SEM Trim Black. Basically a super simple low gloss black that matches most oem trim colors, is easy to spray, easy to touch up and still looks and holds up nice. If that was your choice, sanding and cleaning prep is same, but rather than sealer-color-clear it's just color with the 1.3mm nozzle. It would probably take 3, maybe 4 coats due to the white to black color change. End result would be nice, but just not QUITE as good as the full black base/satin clearcoat route.
SEM also has their Trim Black Ultra which is proper jet black, but unfortunately it's aerosol only. Not a deal breaker as they do spray nicely, but kind of a pain to spray that much from cans.
Also, are you repainting the subs and the speakers or just the speakers?
« Reply #11 on: 27 Aug 2026, 08:19 pm »
Subs and speakers both.
SEM Trim should work fine for what I want  :thumb:
nlitworld
« Reply #12 on: 27 Aug 2026, 08:52 pm »
Sounds good. You'll probably need 2 quarts and two quarts of reducer.
YEEEEGZ
« Reply #13 on: 27 Aug 2026, 09:06 pm »
They look so awesome in white. :cry:
CopperFoil
« Reply #14 on: 28 Aug 2026, 01:02 am »
2 different Porsche Metallic colors.
« Reply #15 on: 28 Aug 2026, 03:43 am »
OK, just to make sure I have the steps right with the current approach:
1. Sand with 400 grit sandpaper and grey scotch bright pads.  Light sanding only, enough to dull the finish but not enough to blow through the base layer
2. Wipe down with the wax/grease remover (and wipe it off IMMEDIATELY, do NOT let it dry on the panel)
3. Wipe down each panel with a tack rag
4. Using the spray gun (1.3mm nozzle), spray the panel with the SEM Trim Black paint.
5. Stop after 3 or 4 coats (when coverage is full).  Let it set for 48 hours before re-assembly.
Is that pretty much it?
nlitworld
« Reply #16 on: 28 Aug 2026, 01:29 pm »
Well Tyson, there was one step you forgot and that was doing a happy dance :banana piano:  after your last coat of paint. But yes, that's the basic rundown for the trim black and will be a very good end result.
Having done a couple paint jobs prior will actually give you a lot of good muscle memory so it will come out really clean.
« Reply #17 on: 28 Aug 2026, 05:28 pm »
How long should I wait between each paint coat?
nlitworld
« Reply #18 on: 28 Aug 2026, 06:36 pm »
On that paint specifically, it's 3-5 minutes. Basically as you spray one coat all the way around, reload and start again. It's pretty forgiving if you take an extra few minutes between, unlike most clearcoats or glossy single stage paint.
hk29
« Reply #19 on: 3 Sep 2026, 07:59 am »
Stupid question, I assume that means you'll remove the drivers, desolder, and remove the no-rez -> then paint and the reassemble again. I assume no-rez will need some spray glue? I was thinking about repainting some speakers as well; but the thought of removing the drivers + cross over is daunting.
