LPSU experience and recommendations for a usb card
NORTH4
« on: 17 Jul 2026, 04:13 am »
For the last year or so ive been satisfied with the sound im getting from my source, but the upgrade itch is back.
At the core of my streamer is a Jcat usb XE card and an LHY branded LPSU. Id like to upgrade the LPSU to something higher quality. The obvious upgrade choice for a Jcat card would be a Jcat LPSU, but id like to hear what your experience has been with LPSU's. What do you recommend?
My source uses a Jcat usb XE, Intel network card, and inline power filtration for the motherboard and cpu.
For software i use Jplay and Fidelizer.
nlitworld
Re: LPSU experience and recommendations for a usb card
« Reply #1 on: 17 Jul 2026, 01:37 pm »
That all looks pretty solid like you've taken very smart steps to minimize any noise issue from source. Plus I love the open chassis concept. I'd suggest possibly looking at next piece of the chain. What's your usb cable and dac setup? Also are you playing local files or streaming? What improvements are you looking to get? More resolution, smoother analog sound, more soundstage, etc?
WGH
« Reply #3 on: 17 Jul 2026, 10:09 pm »
I used Claude to pull power supply specifications from numerous sources, the JCAT INITO 3 looks the best based on the data the manufacturer supplies. Since Acopian is an industrial supplier, their noise and ripple would be the most accurate. The other manufacturer's info may be cherry picking low numbers or marketing, there is no way to tell.
The LHY Audio LPS-15 has excellent published specifications, you would need a JCAT to get lower ripple numbers.
I use an Acopian 5EB100 5v power supply with a JCAT Femto USB card. I haven't tried other power supplies with this card. Using the 5EB100 lps with a Paul Pang USB card very slightly increased the bass and made the sound cleaner, but the change was slight. Upgrading the LHY lps to a JCAT lps is entering the land of diminishing returns. You will definitely hear a difference after spending $1090.00.
JUMPING
The largest jump in quality was buying a Hapa Audio AerØ USB cable, it was much bigger than upgrading to the JCAT Femto USB card.
The second largest jump in quality was the HoloAudio May KTE DAC and HQPlayer combo. I prefer the sound of DSD so all music files are upsampled to DSD256, PCM sounds sharper and doesn't sound as good in my system. Other DACs like the ANK 5.1 Signature sound better if the source is strictly Redbook PCM. Not all DACs work with HQPlayer, the website has an approved list, the main requirement is a NOS DAC. Almost all DACs oversample so their internal filters work. PS Audio DirectStream DAC automatically upsamples all inputs to DSD256 so not a good choice with HQPlayer. Music playing software has it own built in sound, JRiver has a mild mid-bass bump that makes everything sound warmer. I haven't tried Jplay. HQPlayer's sound can be customized using a dizzying array of filters (only a handful are used so not as complicated as it initially looks).
One reason I'm not thinking of a USB power supply upgrade is the HoloAudio has a lot of filtering:
The May uses a discrete multi-stage voltage regulation circuit (not off-the-shelf regulator ICs) built specifically for each internal rail, paired with a separate outboard power supply chassis so the transformer and rectification stay physically isolated from the sensitive DAC/analog circuitry. Holo Audio's own marketing claims the regulation achieves better than 0.2μV output noise — for context, that would put it below even the JCAT/LT3045-class parts, though as with most of these figures, it's a manufacturer claim without a published third-party measurement methodology. The KTE tier goes further with an O-core transformer using flat-wire windings, which produces less flux leakage than a toroidal and is claimed to improve regulation performance further. The May's jitter/latency is also buffered and re-clocked.
Here is the info Claude put together from published data sheets:
Acopian 5EB100
The Acopian 5EB100's actual datasheet ripple is 1000μV (1mV RMS) — a solid, industrial-grade, conservatively-rated number that holds across the whole EB family regardless of voltage/current. Against the LHY LPS-15's claimed 17.28μV, that's a ~58x gap on paper. But remember the asymmetry: Acopian's number is a guaranteed worst-case spec from a formal datasheet; LHY's is an unqualified marketing figure with no stated load or bandwidth — so in practice the real-world gap is likely smaller than the raw numbers suggest, though the Acopian's rated ripple is still probably a more trustworthy floor to build expectations around.
LHY LPS-15
On paper, the LHY LPS-15's advertised ~17μV ripple figure is roughly 60x lower than the Acopian's rated 1mV (1000μV) ripple spec. A few caveats worth flagging before you lean on that number for a real decision:
The Acopian spec is an industrial datasheet number — conservative, tested to a defined standard, and something you can trust as a worst-case guarantee across the full family.
The LHY figure is a consumer marketing spec with no stated test conditions (bandwidth, load, or measurement method aren't published), so it's likely a best-case or no-load number rather than a worst-case guarantee.
Different measurement bandwidths (e.g., 20MHz vs. 100kHz) can shift reported ripple numbers by an order of magnitude on their own, so a like-for-like comparison really needs matching test conditions — which the LHY listing doesn't give you.
Acopian L5MC500 Gold Box Infinity - $40 eBay
Ripple: The L5MC500 is meaningfully better — 0.25mV RMS vs. the EB-series' 1mV RMS, a 4x improvement. And critically, Acopian actually states the test bandwidth (25MHz) for the Infinity series, which the older EB-series datasheet doesn't do — so the L5MC500 number is more rigorously documented, not just lower.
Regulation: Interesting reversal here — the Infinity series specs regulation in absolute millivolts (±2mV for both load and line) rather than percentage, which at 5V output is actually tighter than the EB-series' percentage-based spec once you do the math (±0.25% load reg on 5V is ±12.5mV, over 6x looser than the Infinity's flat ±2mV).
Bottom line for your comparison purposes: If you're sizing this against the LHY LPS-15's claimed 17.28μV, the L5MC500's 250μV (0.25mV) is still roughly 14x higher than LHY's marketing number — closer than the EB-series' 58x gap, but still a real difference, especially since (again) Acopian states its ripple over a real measurement bandwidth and the LHY figure doesn't.
JCAT INITIO 3
JCAT doesn't publish a hard ripple/noise spec for the INITIO 3 itself, but there's enough here to build a solid comparison. Key facts: it uses LT3045 ultra-low-noise linear regulators (same architecture as JCAT's flagship OPTIMO 3 DUO, which JCAT explicitly rates at <2μV noise), a dual-output design (5V or 12V, 3A total), and a shielded/epoxy-potted custom transformer. The LT3045 IC itself (Analog Devices/Linear Tech) is datasheet-rated at 0.8μV RMS typical output noise (10Hz–100kHz) — one of the lowest-noise linear regulators commercially available, which is why it's become a favorite in audiophile PSU designs.
TeraDak
The TeraDak is the weakest entry in this whole set purely on the basis of documentation — not necessarily performance. It's a well-regarded product in the DIY/streaming-audio community (repeatedly mentioned favorably alongside things like the UpTone LPS-1 and HDPlex units in forum discussions), but TeraDak as a company simply doesn't publish engineering specs the way Acopian does, or even make aspirational marketing claims the way LHY and JCAT do. One relevant data point from a forum thread on a related TeraDak product (the ATX-series linear supply): TeraDak told a buyer they couldn't share ripple numbers because they "don't have the numbers on hand" — which suggests this isn't a case of them hiding a number, but of the company not routinely measuring or publishing this spec at all.
Bottom line: if a documented, comparable ripple number is what you actually need to make this decision, the TeraDak DC30 gives you nothing to go on — you'd be relying entirely on anecdotal listening reports rather than anything you could put in a spec sheet next to the Acopian units.
How to think about this ranking
If you trust the manufacturer claims at face value, the rough order from noisiest to quietest is:
Acopian 5EB100 (1mV) > Acopian L5MC500 (250μV) > LHY LPS-15 (~17μV) > JCAT INITIO 3 (likely low single-digit μV, based on LT3045/OPTIMO precedent)
But the caveats matter a lot here, and they cut in opposite directions depending on the product:
Acopian's numbers are the most trustworthy — both are from formal engineering datasheets with defined worst-case guarantees (and the L5MC500 even states its measurement bandwidth). These are industrial parts built to a spec, not marketed for subjective "sound quality."
The LHY figure is unverified marketing copy with no test conditions disclosed — it could be a best-case, no-load number that's not representative of real operating conditions.
JCAT doesn't publish a ripple number for the INITIO 3 at all. The <2μV figure belongs to its more expensive sibling (OPTIMO 3 DUO, ~$2,000), and while INITIO 3 shares the same regulator IC, JCAT explicitly markets INITIO 3 as an "entrance" tier product built to a lower price point — so it likely doesn't hit the same number even if the underlying LT3045 topology is capable of it. The LT3045's own datasheet spec (0.8μV RMS) is the theoretical floor the IC can achieve under ideal conditions, not what any implementation delivers.
I.Greyhound Fan
« Reply #4 on: 17 Jul 2026, 10:45 pm »
WGH, I get your point about specs with the Teradaks, but they make a big difference.  We have 3, 2 powering JCat Cards and 1 a Chord Qutest which Chord says a power supply does not make a difference.  I can say unequivocally that they significantly lower the noise floor and improve the sound.
They are also built like a tank.
WGH
« Reply #5 on: 17 Jul 2026, 11:56 pm »
I agree, Claude should not dissuade anyone from trying out a TeraDak. I had one but for some reason it sat in my closet unused, it felt very well built. The TeraDak is much better than a computer power supply or a wall wart switching power supply. Now I want to try it out but I recently gave it away along with the Paul Pang USB card to a friend putting together a music server.
NORTH4
« Reply #6 on: 18 Jul 2026, 02:13 am »
Thank you for the kind reply fellow MTBer. My source has been a great excuse to learn new diy skills such as; resin printing, making silicone molds, working with epoxy resin, coordinating with cnc shops. Oh and software, less fun  :lol: More to come im sure!
Downstream from the source will be getting an overhaul soon. I am actively researching dacs and will be looking for a usb cable next. Currently im using an Oyaide usb, gustard U18, and the Technics SU-R1000s integrated Dac. I primarily stream but also have a small collection of local files.
By upgrading the LPSU id like to hear a lower noise floor, deeper black, improved timing, and in general a more analog sound.
NORTH4
« Reply #7 on: 18 Jul 2026, 02:47 am »
I use a JCat Femto USB card and power it with a Chinese Teradak LPS and it works great with an improvement in clarity.
Ive read positive things about the Teradak LPSU’s, good to hear you like their sound with a Jcat card.
They look to be an excellent value. Id prefer to avoid made in china products, although for 145$ it may be worth while to purchase for comparison’s sake.
nlitworld
« Reply #8 on: 18 Jul 2026, 04:35 am »
If that's the case, try to find a Hapa usb cable as WGH suggested. I have the Aero Cu, I think Wayne has the Aero Ag which I love, and the entry tier Ember is also fantastic. Can't recommend enough. Several review threads here about them where I go on and on like a bad relationship columnist.
Also, those are some pretty sweet new skills you've been working on. Definitely in the 300 level DIY course territory.  :thumb:
I.Greyhound Fan
« Reply #9 on: 18 Jul 2026, 04:22 pm »
You can find them for under $100 but that depends upon what voltage and wattage you need.  I agree, I do not like buying chinese gear but I need 3 of them.
https://www.aliexpress.us/w/wholesale-Teradak-linear-power-supply.html?spm=a2g0o.productlist.search.0
NORTH4
« Reply #10 on: 19 Jul 2026, 02:34 am »
Thanks for sharing WGH. Ripple and noise is a reasonable metric to judge these LPSUs by without being able to listen to them all. The better measuring units are often preferred in the comparisons ive seen online. Its unfortunate the numbers are manufacturer provided and potentially from cherry picked units.
That’s impressive you saw a significantly larger improvement from the Hapa usb than from the Jcat card. I will definitely consider Hapa when looking for a new usb cable. Im still figuring out what the optimal front end looks like in my system.
The marketing for the Optimo sure is compelling,  “the OPTIMO 3 DUO will drastically improve every aspect of sound” – Jcats website.
Rusty Jefferson
« Reply #11 on: 19 Jul 2026, 02:04 pm »
HDPlex 300 watt LPS is a good option. Run the motherboard and both JCAT cards from the same supply while isolating the grounds. Several locals here are doing just this with their servers and JCAT EX cards. Very good upgrade.
https://hdplex.com/hdplex-fanless-300w-linear-power-supply-for-pc-audio-and-ce-device.html
Also, I'm not sure what your "inline filter" is, but if you try the HDPlex you should also try the server without that filtering. Generic filtering to suppress noise from a typical smps on the motherboard can just kill resolution and dynamics including from the LPS.
WGH
« Reply #12 on: 19 Jul 2026, 06:25 pm »
Yes, the HDPlex is an elegant all-in-one solution to get clean power to all the parts in a music server. I looked at HDPlex LPS when I was building my server but the price forced me to explore other options. I can't find a current price on their website and the videos are missing, always a bad sign. The old price was around $685.00.
What I noticed is the ripple of the HDPlex 300w is under 1mV, exactly the same as the Acopian 5EB200 ($30 on eBay) I use to power the JCAT Femto USB card. I use a Acopian B5G400 Load 0.3 %, Line 0.1%, Ripple 1.5 mV RMS to power the internal SSD, removing the SSD from the computer's main power supply does make a difference. The HDPlex 300w beats my LPS in ripple. The Streacom ST-ZF240 ZeroFlex 240W Fanless Passive PSU ($175) has 50 mV ripple on the 5 volt line and 100 mV on the 12v line but I don't use the 5v line. The Streacom LPS fits nicely into the music server's Streacom FC10 Alpha fanless case minimizing case clutter. I have limited room for all my stuff.
Acopian 5EB200 for the JCAT Femto
Bench test layout. The small white box with the two rocker switches are the USB card and SSD on/off switch. The Acopian B5G400 for the SSD (on end) is a stand alone box that is tucked away in the equipment rack, it's too big to fit in the Streacom case.
Acopian LPS are not for everyone, especially households with children running around with forks because all the electrical connections are exposed. Acopian position themselves as serving noise-sensitive, mission-critical sectors — they describe having been trusted since 1957 by industries including aerospace, telecommunications, medical, defense, and energy for applications requiring exacting specifications and reliability, and they highlight a case where an aerospace company chose Acopian to build custom rack-mounted linear regulated DC power systems for all cockpit components on a flight system.
The Series A (linear) supplies are low-noise by design, and Acopian markets that characteristic specifically toward aerospace/defense/critical-electronics customers.
A fun read:
Audio Bacon: The World's Best Audiophile Linear Power Supplies
https://audiobacon.com/the-worlds-best-audiophile-linear-power-supplies/
WGH
« Reply #13 on: 19 Jul 2026, 06:49 pm »
Claude comes up with interesting power supply suggestions of companies I have never heard about:
PLiXiR Elite BDC 4A / 6A Dual Output Balanced DC Power Supply Review - $1164.00
https://www.stereonet.com/reviews/plixir-power-elite-bdc-linear-power-supply-review
Claude summarizes the Plixir Elite:
Plixir Elite BDC 6A: less than 1mV rms residual noise at DC output.
That's a noise figure rather than a strict "ripple" figure in the traditional peak-to-peak sense, but it's the number Plixir quotes across their entire Elite BDC lineup (2A/4A/6A versions), and it appears consistently whether from Plixir's own listings or third-party retailers (HiFi Corner, Audio Affair, Expressive Audio, Alex Sound Technology).
Design-wise, this comes from their two-stage regulation topology: an open-loop first-stage discrete-transistor pre-regulator handles the bulk of the high-frequency noise and heat dissipation, followed by a closed-loop feedback second stage that does the fine regulation — Plixir calls this the "brawn and brain" approach. They also use a balanced (dual-winding, center-tapped) AC transformer design specifically to cancel ground-loop current and reduce diode rectification noise, which is a step beyond what HDPlex or UpTone describe doing.
So interestingly, both Plixir (<1mV rms) and HDPlex (<1mV, though phrased as general "ripple noise") land on the same round number, while UpTone doesn't publish one at all — despite the design philosophy pages all reading similarly confident. Like the HDPlex figure, this is the manufacturer's own claim
I.Greyhound Fan
« Reply #14 on: 20 Jul 2026, 03:36 pm »
WGH, you can google the Ripple and specs of Teradak LPS.  The X2 Teradak has a ripple of 0.2mV.  The 30 watt version is less than 0.05 to .15mV depending upon the load.  These are very low numbers.
While I have no doubt that more expensive LPS's sound better, the question is how much and is it worth it to spend $500 and up into the thousands for a better LPS.
WGH
« Reply #15 on: 20 Jul 2026, 08:51 pm »
Thanks for the Teradak ripple numbers. I found a couple more discussions regarding linear power supplies:
Audiophile Style has tests of 9 LPSU
https://audiophilestyle.com/forums/topic/31119-power-supply-8-group-test-lps-and-smps/#comments
AudioCircle has a thread I forgot about
< or = $700 Linear Power Supply Comparisons
https://www.audiocircle.com/index.php?topic=155847.0
Page 4 has some interesting results although a DAC is not the same as a simpler USB card
AC member viggen made the final post writing:
"i got the ifi because of this thread and used it for about a year powering a element h usb card.  there's a small improvement in sound.
"recently replaced the ifi with, coincidentally, the same 65va lpsu wushuliu linked in the first page of this thread.  there's a massive improvement as result.
"so, depending on what you're powering, noise is probably not the only thing that matters.  larger power reservoir is probably important too."
Note: there is no way to know what LPSU viggen bought, the eBay listing is over 8 years old.
zoom25
« Reply #16 on: Yesterday at 02:32 am »
I'm running two Teradak LPS.
The first one is the Teradak 12V13A for the DAC. This has been powered on continuously for the last 12+ years with only a few breaks to shuffle stuff around. Runs cool. I use it to power my DAC that only needs 12V 2A, so the Teradak is quite oversized, but was told from other members that they had good luck by overspeccing it. Sounds good to me!
The other Teradak LPS is the X1/X2 or maybe it's the U9. Anyways, got that one in particular for cheap to make use of the 5V USB output. I use this to power my D-Link network switch. I have 3 of them (5 and 8 ports) and they are all rated for 5V. Again, noticeable benefit in comparison to the switches' stock switching power supplies.
