Cabinet Resonance
txrx232+AudCir
Cabinet Resonance
« on: 28 Jun 2026, 03:45 am »
I'm curious about using the spray-on material used in truck beds sprayed on the internal surfaces of speaker cabinets to reduce resonances. Does anyone have expeience with this or a similar technique?
Danny Richie
Re: Cabinet Resonance
« Reply #1 on: 30 Jun 2026, 12:04 pm »
That material does almost nothing for resonance control.
jtwrace
    • TIPP YouTube Channel
« Reply #2 on: 30 Jun 2026, 06:21 pm »
If you're set on a diy method, this does work well when properly applied.
https://www.acrytech.com/product/acoust-x-sound-damping-coating-1-gallon/
Danny Richie
« Reply #3 on: 1 Jul 2026, 10:49 pm »
We stock and sell that product. It is a nice durable and easy to apply coating for the outside of a speaker. However, it does little to nothing for resonance control.
jtwrace
« Reply #4 on: 2 Jul 2026, 06:42 pm »
That's interesting, I've never heard you mention Acoust-X Sound Damping Coating which is specifically for the inside, I've only seen you mention DuraTex which this clearly isn't.
Norman Tracy
    • Audio Crafters Guild
« Reply #5 on: 2 Jul 2026, 07:20 pm »
jtwrace,
What is your personal experience upon which you base "this (Acoust-X Sound Damping Coating) does work well when properly applied"? Does it cure hard like a bed liner or softer so it can provide some limp mass damping effect?
Visiting the link I find no real details or measurements. Disappointing, for a manufacturer it is not that expensive to run tests with accelerometer data. There is one review that is for a PA speaker application. They do reiterate applying in a thick coat and then a second coat "if needed". Reading between the lines with my engineer's skeptic hat on if evaluating it I would expect to apply two thick coats to obtain some effect.
If Acoust-X Sound Damping Coating cures hard my experience is that is producing a simple mass loading effect and such avenues yield disappointing results in the context of high-end HiFi speakers. Its the compliance + mass in products like GR's No Rez and 3M's Damping Foil 2552 that achieve wider range panel damping.
