Speaker stand material for SAM
swong61
  • System: AT-LP7, MM photo, KT170PP/300B SET, LRS+
« on: 20 Jun 2026, 08:33 am »
Hi there, I'm thinking to source a pair of stand for my on-the-way SAM.
Is the speaker design more suitable with wooden or steel frame?  :)
Your advice is welcome!
seikosha
Re: Speaker stand material for SAM
« Reply #1 on: 20 Jun 2026, 12:44 pm »
I don’t think the speaker will care what the material of the stand is as long as the stand is rigid and at the correct height.
swong61
« Reply #2 on: 20 Jun 2026, 01:07 pm »
Hi Seikosha, thanks for your advice.  :)
mick wolfe
« Reply #3 on: 20 Jun 2026, 04:41 pm »
I'm in agreement with seikosha. However, what one might experiment with is a form of decoupling between the stand's top plate and speaker bottom. This especially if the stand is spiked to the floor. I've successfully used IsoAcoustics Mini Pucks for years under standmounts. Many other options here as well including Herbie's. Enjoy your new speakers.
swong61
« Reply #4 on: Yesterday at 01:25 am »
Hi Mick Wolfe, my place is wooden floor and I plan to get one with spike and a disc/cone that protects the floor.
Will have a look at IsoAcoustics. Thanks for your advice :)
mick wolfe
« Reply #5 on: Yesterday at 04:16 pm »
You're welcome  :thumb: If it's a suspended wood floor, you definitely want to bring a form of decoupling into play. If it's wood over concrete, decoupling should still be considered.
