Need advice on amp upgrade
whodiini
« on: 19 Jun 2026, 11:25 pm »
Hi.  I have been a long time nuprime user.  With the improvements in your lineup, I am having a hard time deciding on which amp to upgrade to.  Currently I use the MCX-2 and want to keep all the wonderful aspects of this amp, but with increased detail (not edginess) and a more extended high end. I like that it has enough power and control so that the bass is tuneful, well controlled and seemingly limitless power.  It has a slight warmth and sweetness, but not excessive. Reasonably wide and deep soundstage, but not quite as layered or specific as others. A nice to have would be a better layered soundstage, but I would be fine keeping the same as now.  Previously I tried a IDA-8, which had all the characteristics of the MCX-2 but limited dynamics/power. ST-10 was too edgy and brittle on the top end. ST-9 was too warm and lacked detail.  The amps that sound interesting are the Evo STA SE, the IA-9XG, IDA-9, and the fusion 2X. Previously I simply bought all the amps and tried them one at a time, but that gets expensive, so I wanted an educated opinion on which one you think would work for what I am looking for.  I have been trying other brands of class D and while they excel in one area or the other, they lack the musical involvement that my MCX-2 has.  Thanks.
John Casler
Re: Need advice on amp upgrade
« Reply #1 on: 19 Jun 2026, 11:35 pm »
What speakers will this amp(s) be used with, and is it treated?
whodiini
« Reply #2 on: 20 Jun 2026, 12:04 am »
I generally use goldenear triton 7, sometimes with a vandersteen sub.  I have other amps, speakers but this is my lifestyle system that I use the most and am looking for a nuprime amp to upgrade to. For critical listening, I have several tube amps, another pair of Vendersteen subs and a quad 2905, but that is a separate issue. I tend not to do critical listening anymore and just want to enjoy without  the hassles. My front end for my lifestyle system is a eversolo T8, a Schiit Yggy OG2 and Schiit Freya preamp. I do not do room treatment as the speakers are positioned in a place where the rear wall is 15 feet away and the wall has a cutout at ear level and the sides have cutouts as well, so room reflections are minimal.  I have tried room correction and the best room correction was worse to my ears than none at all because the clarity and soundstage are affected. Lyngdorf I think has better room correction than DIRAC. So I try to minimize the need for room correction and not use it.
mresseguie
« Reply #3 on: 20 Jun 2026, 07:15 am »
Based on what you wrote above, I suspect we share some similar likes and dislikes in amp characteristics. Like you, I purchased the IDA-8; IDA-16; ST-10; EVO STA, and the EVO STA-SE. The IDA-8 was excellent in a small room with reasonably efficient 2-way speakers (86dB/8 ohm). I gave it to my son as a house warming gift. I found the ST-10 and IDA-16 too edgy and/or bright as well. For me, both the EVO STA and EVO STA-SE are winners. I bought the EVO STA a few years ago, and I have happily used it as my summer/hot weather amp or when my tube gear misbehaves. I've powered 2-way and 3-way standmount  speakers and 3-way floorstanders with it, and it has done a great job of powering them. It's a warm (but not syrupy) sounding amp that pairs well with my SS and tube preamps, and even with my DAC w/volume control.
When it came time for me to buy a SS amp for my vacation home, experience had taught me that I needed a serious power to make my 82.5dB 2-ways sing. I was on the verge of buying a pair of the STA-9x to use as mono amps when both John and Jason grabbed me; threw me to the ground, and threatened me with bodily harm unless I relented and chose the new EVO STA-SE instead. [In my old age it's possible I mis-remembered a part of the selection process. :wink:] Anyway, I did choose the EVO STA-SE, and I have been delighted with its performance and sound these past 5 months. It's paired with a Holo Audio Spring3 KTE and either a CD player or Tidal via my laptop.
I cannot tell you how the EVO STA and EVO STA-SE compare because they were never under the same roof nor have they powered similar gear. I can say that I'm happy with each one, and that I have no intention of selling either. I may yet upgrade the EVO STA to SE level as Jason has made it very affordable to do so.
Should you find yourself wandering near the Willamette Valley in Oregon....shoot me a PM. If I'm home and not wearing myself out chasing my 2-year old grandson, you're welcome to come listen to some tunes.  :thumb:
Michael
rustydoglim
« Reply #4 on: 20 Jun 2026, 12:10 pm »
We reorganized the Amp Comparison chart to split the home series from the evolution and AMG series:
https://nuprimeaudio.com/guides/amp-comparison/
If you stay in the home series price range, then the top end amp that you should consider upgrading to is the STA-9X (bridge into mono).
Since you like the MCX-2 and want to take a step up, you can consider the Fusion 2X or go with Fusion-3X and use MCX-2X for the surround channels for 5.1 immersive music.
whodiini
« Reply #5 on: 20 Jun 2026, 03:30 pm »
Thanks @mressesguie!  It does sound like our ears are similar wrt to sound.  And thanks for the generous offer to stop by.  I have yet to visit Williamette Valley - the wines from that area are excellent!
Thanks @rustydoglim.  I do have a question - from your and @mressesquie's response, I am tending towards the Fusion 2x or the Evo STA SE.  I have listened/owned previously the STA-9 and found it too warm/flabby.  If the STA-9X has the same coloring, I dont think I would like it. I looked at your table and was curious also about the IDA-9.  What DAC does the IDA-9 have inside.   Not sure why you did not recommend that as well, as the rankings show it is a contender.
