FYI
Yes, you can absolutely connect a Rythmik subwoofer to a [Bryston BR-20](
https://bryston.com/preamps/br-20/) preamplifier, and because both are high-end audiophile components, they will pair beautifully. [1, 2]
The Bryston BR-20 features two pairs of balanced XLR analog outputs on the back panel. This makes connection straightforward depending on your exact amplifier setup. [3, 4]
## Option 1: The Balanced Dual XLR Method (Recommended) [5]
This is the cleanest, most audiophile-grade connection method if your power amplifier uses balanced connections. [1]
* The Setup: Connect the first pair of Bryston BR-20 XLR outputs to your main power amplifier to drive your stereo speakers. [1]
* The Sub Connection: Connect the second pair of XLR outputs on the Bryston BR-20 directly to the Line-In XLR inputs on your Rythmik subwoofer. [1]
* Crucial Note: In the Bryston BR-20 software control settings via the Bryston WebUI, make sure both XLR pairs are configured as Variable Outputs so that the preamp volume control adjusts both the speakers and the subwoofer simultaneously. You must connect both Left and Right channels to the subwoofer. [1]
## Option 2: Using a Single-Ended Adapter (If your Sub lacks XLR)
Some entry-level Rythmik models (like the Rythmik L12) only have RCA inputs. Since the Bryston BR-20 only outputs via XLR, you can still make this work cleanly. [6]
* The Sub Connection: Use a pair of high-quality XLR-to-RCA cables or adapters from the second pair of XLR outputs on the Bryston BR-20 into the RCA inputs on your Rythmik sub. [1, 7]
## Dialing in the Integration
Because the Bryston BR-20 does not have built-in digital bass management (it outputs full-range audio to both pairs of outputs), you will rely on the physical controls on the back of the Rythmik subwoofer to blend the sound. [8]
* Set the Rythmik's Low-Pass Filter (LPF) to match the natural low-frequency roll-off of your main stereo speakers.
* Adjust the Phase and Gain knobs on the Rythmik to make sure the bass hits perfectly in time with your main speakers. [8]
To help you get the exact cables you need, which Rythmik subwoofer model are you planning to use, and what power amplifier are you running with your Bryston BR-20?
[1] [https://www.audiocircle.com](
https://www.audiocircle.com/index.php?topic=172721.520)
[2] [https://bryston.com](
[3] [https://sepeaaudio.com](
https://sepeaaudio.com/high-end/network-streamers/bryston-br-20-flagship-stereo-audio-preamplifier-streamer-17-black-used-like-new/)
[4] [https://support.bryston.com](
https://support.bryston.com/downloads/Brochures/Bryston_BR-20_Brochure.pdf)
[5] [https://www.hifinews.com](
https://www.hifinews.com/content/bryston-br-20-networkdac-preamp)
[6] [https://en.homecinesolutions.fr](
https://en.homecinesolutions.fr/p/30872-bryston-br-20)
[7] [https://tile.loc.gov](
https://tile.loc.gov/storage-services/master/mbrs/recording_preservation/manuals/Bryston%20Models%20BP-20%20and%20BP-25.pdf)
[8] [https://www.youtube.com](
https://www.youtube.com/watch?v=Wo5TwacV7-c)
