Soon-to-be Newbie from Australia
Steven Wong
  • System: Benchmark DAC USB, 300B SET, Omega SAM
« on: 14 Jun 2026, 11:07 pm »
Hello all, this is Steven from Sydney. Nice to meet you all.
I own a SET amp which is just about 8Wpc and ordered the SAM to hope for a nice match and happy listening  :D
Re: Soon-to-be Newbie from Australia
« Reply #1 on: 14 Jun 2026, 11:28 pm »
Welcome to AC  :thumb:
Tell us something about your SET amp ?
seikosha
« Reply #2 on: 15 Jun 2026, 12:19 am »
What speakers are you replacing?
Steven Wong
« Reply #3 on: 17 Jun 2026, 07:16 am »
Hi FullRangeMan :D I have a 300B SET (8WPC).  :roll:
It's made in Hong Kong and I found it more affordable than those I could find in the market in Australia.
The tube is EH300B (not gold plated). TBH, I'm a newbie to tube audio too since last year :)
« Last Edit: 17 Jun 2026, 09:43 am by swong61 »
Steven Wong
« Reply #4 on: 17 Jun 2026, 07:18 am »
Hi seikosha, I've retired my JM Lab Chrous 707S (bought in 2008) with the maggie LRS+ last year.
However I want a pair of SAM dedicated for mucic :)
« Last Edit: 17 Jun 2026, 09:44 am by swong61 »
Steven Wong
« Reply #5 on: 26 Jun 2026, 07:41 am »
All of a sudden, 'Sam' doesn't arrive today and I have to pass a lonely weekend myself till Monday.  :popcorn:
I did a few of my research that some owners found 'Sam' wakes up to be a better 'person' after 100hrs.
I hope I don't have to run that long or otherwise cover it with a quilt and play overnight with a SS amp :)
« Reply #6 on: 27 Jun 2026, 02:36 am »
Looks a nice amp, Congratulations.
« Reply #7 on: 27 Jun 2026, 02:43 am »
I would suggest not leaving this amp(or any other audio equipment) power on for long periods.
Especially if the weather looks like rain.
Steven Wong
« Reply #8 on: 29 Jun 2026, 12:48 pm »
Hi FullRangeMan, thank you  :D The 300B is now in a box and I need to wait until the weekend to unbox the pair of SAM that just arrived this afternoon. They are bigger than expected  :)
Steven Wong
« Reply #9 on: 29 Jun 2026, 12:51 pm »
Thanks FullRangeMan for your thoughtful reminder! My roof did leak a few times last year until it was fixed early this year. Perhaps I just warm them up in an ordinary way.  8)
Steven Wong
« Reply #10 on: 4 Jul 2026, 10:21 am »
SAM finally sings on a temporary stand but sound signature is so different from LRS+.
Need to switch back to 300B SET for its full potentials.
Will see if I can source a better stand for his proper performance  :D
uncola
« Reply #11 on: 5 Jul 2026, 12:17 pm »
cool setup!  yep I'd imagine they sound very different from magnepans
Steven Wong
« Reply #12 on: 4 Aug 2026, 02:47 am »
Hi Uncola, yea, it sounds very differently and I like both of them for different purpose.
Now I just leave SAM at the place for burn-in period before my new wooden stand arrives  :D
« Reply #13 on: 4 Aug 2026, 03:06 am »
Do these drivers have paper Voice Coils form as is usual in fullrange drivers ?
If your SAM speakers have paper VC I would not leave these speakers running for very long periods, especially if you are using a tube amp.
EDITED
« Last Edit: 4 Aug 2026, 05:58 am by FullRangeMan »
Steven Wong
« Reply #14 on: 4 Aug 2026, 08:39 am »
EDITED
Thanks FullRangeMan! I just played it for half day which is long for me. I was told by tube friends that tube amp should not be switched on and off often or shorten the tube lifespan.
SAM is paper cone and sorry I dont get you about VC.  :oops:
« Reply #15 on: 6 Aug 2026, 03:41 am »
Do you mean say you run your tube amp and an paper Voice Coil Form for 12 hours ?
Yes most fullrange drivers use paper cone for better sound quality than Plastic or Metal cones.
Many years ago was common to use in the VC Form Kraft paper or Stamping paper, but today there is new options as Ceramic paper or Mica paper etc
About the Voice Coil Form:
There is VCF in various materials according the driver intended use.
For hi temp applications as Pro-audio, Car audio, PA, etc is used Copper, Aluminium, Nomex, Kapton etc in the Form.
For precision Hi-End fullranges is mandatory use paper Voice Coil Former to get  extreme fidelity in musical reproduction in timbre and harmonics.
Unfortunately Paper Form do not withstand high temp like the other materials mentioned above.
« Last Edit: 6 Aug 2026, 06:10 am by FullRangeMan »
Steven Wong
« Reply #16 on: 6 Aug 2026, 09:31 am »
Thanks for all the information.
I set the volume volume to ~1 o'clock on my 300B whilst my daughter with even just 11 o'clock.
The output should be very mild especially I set it to low gain and its max output is just 7Wpc.  :)
If I listen to pop music, I might consider to switch back to KT170 with the LRS+ which should be very safe  :D
