Hello,
it's me from Germany again...
My BDP-2 still has the original sound card (prior IAD kit) and an internal SAMSUNG SSD 1TB with all my music files on it (all .mp3 320kbps 44-48kHz, 180GB with 25.000 files used). I unfortunately have a problem playing these songs using MM through MPD 0.19.21 (changing to 0.18.21 does not help) and coax output. The music being played interrupts (gaps from 2 to 10s once in each song). Time counter from Music Player also stops during the gaps. Playlist length and source don't matter (tried different length 2 to 1000 songs either from internal SSD or thumb drive at ext. USB). Checked the library, but no corrupted file found. Meta data all o.k and will be displayed in Music Player. All reboots, DB updates etc. didn't change a thing.
Now i recognized the following strange phenomenon:
I did a backup over LAN of the 'media' folder at the BDP SSD to my PC (Windows). It took 1,5hours. During that time i played music with the BDP. AND during the transfer time (1,5h BDP SSD busy), not a single interruption in the songs!!! After the end of the transfer, the gaps in the songs appeared again. Confirmed that twice by backing up the folder again and again: transfer -> no gaps, transfer finished -> gaps again...
I have no clue, what's causing this behavior and what the solution could be (i cannot copy files all the time when i use the BDP)? Any idea would be very appreciated. Please help (contacted official BRYSTON support already, but no reply yet).
For the moment i can not listen to my DAC with USB connected (no analog connection to my equipment), to tell whether there are interruptions too (indication stays locked at 44/48kHz during the gaps). Working on it...
Just some additional information:
According to my ANTHEM processor, who receives the digital signal from the BDP, the PCM stream is not interrupted. Just the music on it. When listening to BDP's bRadio there is no interruption at all.
I did benchmark the BDP SSD through the dashboard disk information:
- Bench without active transfer of files to the PC: 27.0MB/s
- Bench with active transfer of files to the PC: 58.8MB/s
Cheers
Joerg Richter
