M2Tech HiFace Karma
M2Tech HiFace Karma
« on: 25 Apr 2026, 06:54 pm »
Greetings, offered for your enjoyment is an original M2Tech HiFace USB>coax unit. It hasn't been used in a long time, but nada in it that should wear out if it had been. I used to use it to kernel-stream from my Win XP Pro laptop, replaced it with the HiFace 2 unit as the original wouldn't kernel-stream in Win 7. According to current available info on the web it should still work with Windows versions to Win10, and does work with Win 11 but with some issues. For Windows operation drivers must be downloaded & installed, for MAC users it should work native. Not sure about later versions of Linux. The white one on the left is the unit offered here. The black unit is the 2 unit, and was gifted to another ACer some time back who said it worked well with streaming from his phone.
So if you are interested pick a number between 1-50, on May5th I'll throw the numbers into a hat and pick a winner. (if there is any interest) The winner can pm me their name/address info and I will mail the unit USPS ground at no charge in the contiguous US. Apologies to our International members, I don't think it's really worth the paperwork to ship otherwise. It will be boxed in the original box fwiw, and weighs only slightly more than a couple of half dollar coins. Have at it gents & ladies, it either gets put to use or pitched. Good Luck.........
brooklyn
Re: M2Tech HiFace Karma
« Reply #1 on: 25 Apr 2026, 08:41 pm »
While I cant use something like that at the moment.. thank you very much for the offering..
nlitworld
« Reply #2 on: 26 Apr 2026, 01:14 am »
That's a very nice offer. I'll put my name in the hat for this. How about #6
Good karma is always a  :thumb:
-Lloyd
« Reply #3 on: 26 Apr 2026, 04:54 am »
19
marvda1
  • freelance reviewer: The Sound Advocate
« Reply #4 on: 28 Apr 2026, 12:19 am »
36
whell
« Reply #5 on: 28 Apr 2026, 01:15 pm »
29
Thanks for offering this!
SteveFord
« Reply #6 on: 28 Apr 2026, 07:45 pm »
Not in but thank you for doing this.
« Reply #7 on: 4 May 2026, 04:04 pm »
Bump ! Drawing tomorrow.
« Reply #8 on: 5 May 2026, 08:34 pm »
We have a winner gents, marvda1, come on down.  :banana piano:   If you'll shoot me a PM with your current mailing info I'll try to get it out in the next few days. I hope it works well in whatever application you have planned.
Thank You to those who participated. May we all have a great Summer, and mild weather. TTFN
