Hi Guys,
Several weeks ago I bought a Parks Audio Waxwing phono stage and I’d like to share my impressions for those considering a flexible, DSP-based option in this price range.
The Waxwing is an incredibly versatile unit in my opinion. The ability to adjust loading, gain, EQ curves, and even apply click/pop reduction and other DSP features makes it stand out immediately from more traditional analog-only designs.
Setup is straightforward, and easily connected to my iPhone and I had a host of options to use such as gain, the ability to increase/decrease treble and bass controls.
Sonically, the Waxwing leans toward a clean, detailed, and highly controlled presentation, however, you do have the option to adjust its sound via FX. For example, I either use 2 Tube or Tape options. The noise floor is low, and it does an excellent job extracting fine detail without sounding clinical or fatiguing. Bass is tight and well-defined and can be adjusted as well, midrange is clear and neutral, and the top end has good extension. This phono stage is transparent and easily reveal good or poor quality vinyl.
I found the Waxwing to be superior to the AVA Vision phono stage, Clearaudio Basic, and Lehmann Audio Black Cube Statement. In those matchups, the Waxwing offered a wider soundstage, better resolution and greater dynamics. It simply sounded superior to these phono stages.
Compared to higher-end designs like the Hagerman Trumpet or the internal phono stage of my Spread Spectrum Technologies Ambrosia, the Waxwing doesn’t reach the same level of dimensionality, harmonic richness, and “you are there” realism. Those units still have the edge in terms of natural timbre and overall musical engagement. However, the Waxwing does give them a run for their money!
Where the Waxwing really excels is in value and adaptability. For its price, it delivers a level of performance and feature set that is hard to match. It’s especially appealing for users who like to experiment with different cartridges, EQ curves, or who want the ability to fine-tune their system without constantly swapping hardware. The Waxwing does sound a little digital if using the basic FX option, however, using the tube or tape options I find gives it a real vinyl sound to the music.
Overall, the Parks Audio Waxwing is a highly capable and forward-thinking phono stage. It may not dethrone top-tier analog designs, but it comfortably outperforms many well-known units in its class while offering a level of flexibility that few competitors can match.
I hope you enjoyed my comments regarding this capable DSP phono stage!
Regards Rod
