Hi There - Due to life requirements, I am planning to move my Kismet Ref floorstanders to a small room oddly shaped with a 5th angled wall, an open hallway exiting the room, and two other doors in the space with a low 81" ceiling. If the fifth wall wasn't in place, it'd be roughly 10.5'x11'. Not an ideal set up at all, really.
I'm wondering due to the 'monitor' style build of the floorstanders, if I were to plug the rear ports with foam inserts, and listen in a near field config, do you think this could work with decently tight bass and not overcharging the small space.....or am I just truly jousting at windmills with an impossible situation?
Note these Kismets are 42" tall as opposed to the 45" standard model, and sit on Mapleshade footers on Butcher Blocks, on some Herbies gliders, so fairly isolated.
Appreciate any input!
Thank you
~B
