Measuring Input Impedance
bertdw
« on: 25 Mar 2026, 04:49 pm »
The other day I thought I'd measure the input impedance of my Khartago Mono amps.  I wanted a more specific number than "greater than 10K."  After turning the unit off and waiting 10 minutes, I connected my Simpson 260 to the input.  It read 10K at first, then slowly climbed to above 20K, like a capacitor charging.  I can't imagine a cap that large connected to the input, so I can't imagine what's going on.  Does anyone have any ideas?  Thanks!
klaus@odyssey
    • http://www.odysseyaudio.com
Re: Measuring Input Impedance
« Reply #1 on: 26 Mar 2026, 09:12 am »
Yes,  it is 22 K...actually,  22.1K to be precise
bertdw
« Reply #2 on: 26 Mar 2026, 10:53 am »
Thank you Klaus!
jeffreybehr
« Reply #3 on: 26 Mar 2026, 08:31 pm »
If one gets a nonstable resistance number when doing this, the input probably is filtered with a capacitor in series, which is not correctly measured with a simple Ohms-meter.
bertdw
« Reply #4 on: 27 Mar 2026, 12:48 pm »
If there was a DC blocking cap at the input, the reading would climb to near infinity, it wouldn't stop at 20k. Unless it was a very leaky cap!  :green:
