I use ported subs with Dolby Surround only.
But, considering I also use Apple Music for streaming … it means I use them a lot for general music listening.
System: 7.2.4 surround in a 20x30’ room with 11.5’ ceilings.
I built all the speakers EXCEPT 2 ported subwoofers: JBL 12” & Polk 12” … plate amps on both failed after about a year. Replaced with equivalent plat amps from Parts Express… though I think the PE amps are more real power & have now lasted years.
x-Statics wired through high band pass filters, full output goes to Double Trouble OB subwoofers… have a couple of mono blocks to feed the X-Statics after filtering 1st Octave (-63Hz).
I do like this setup. The DT subs are amazing musically. & the porters do generous with explosions & earthquake effects.
In Stereo mode it’s just the DTs & X-Statics … the high band pass filters I’ve effectively made the two speakers an integrated 4-way speaker design… Danny might disagree with this opinion.
Anyway the system works great for HT, Apple ‘Spatial’ music … or even Stereo.
Note, if you haven’t listen to Billie Elish or Taylor Swift or The Maria’s or even Domonique Fils-Aimè in Surround Sound you haven’t listen to their music … not really. They engineered the Surround Mix … it’s so much more interesting than the synthetic after the fact automated mixes…
