Just to update I did get some Chinese 8 pin dip mounted opa1622 op-amps with two resisters ? and two capacitors 01c on a small circuit board which only seem to filter 100k+ ? and above but , from Aliexpress, never the less After I removed the excellent LME49720's I had in it and plugged them in the amp. Well, it sounded great, simply great. More detail was there as well as seemingly more tube like harmonics. I think larger caps maybe 1mfd etc would make for better filters but it seems they meant nothing in this circuit?
I didn't expect much suspecting that they might be fakes, less than $20 shipped, but I believe that the Omega 3 never sounded better and don't think it could really. The opa1622 is rated for 125 degrees C or 257 degrees F vs 70c for the AD827 and has great specs and is often used to drive headphones. But, is not for all circuits, so next I will try them on my Fosi ZA3 as well as the LME49720's. So far that cheap little amp amp amazes me for the price and drives my Von Scweikert VR2 speakers well but not my NHT 3.3 speakers which are in a much bigger room etc.. But I think either two of them in mono or better yet two Fosi mono V3's could do the job although not with the tube like sound.
My search for the best op-amp to replace the original AD827's is over and I am happy. It was actually an easy fix and very worthwhile upgrade, imho, because Frank had mounted both of them them in sockets right in the middle of the two circuit boards.
I have always liked the sound of tubes and had built my first kit a Dynaco 70 when I was 12/13 but Tubes need
highly efficiency speakers to sound their best and even KT88's are good for only about 40-50 watts a channel which can current starve a lot of woofers. Mosfet amps like my Omega 3 440 (220w into 8 ohms) are very inefficient, hot running, power hogs, just like tubes, but they sound a lot like tubes too and can drive very inefficient speakers easily. Unlike regular transistors mosfets are easy to parallel too. I just love their even order harmonic tube like distortion. It might not be for every body but it is what I grew up hearing so it might be a required taste? There is no perfect system but for tube like sound go tube or mosfet imho.
