Advice on setup please
bcugk
« on: 25 Feb 2026, 02:36 pm »
Hi,
I’m a couple months I’m moving to a condo from a house, currently I have two independent setups in the house, a 2 channel setup in a music area and a 5 channel.setup in a media room
Excluding sources and speakers the setups contain
2 channel Bryston 4BSST/BR20
5 channel Anthem MCA50/Bryston Sp2
The future system will become a fronts and center only ie no rear speakers for TV/movies, and the 2 channel system
If I pre out the fronts from the SP2 to the BR20 home theatre bypass the 5 channel power amp is only powering the center speaker.
Seems ridiculous but I want the SP2 sound vs a crappy AVR (been there lol)
Am I missing something obvious, please comment and advise
Mag
Re: Advice on setup please
« Reply #1 on: 25 Feb 2026, 05:52 pm »
Depending on your Front speakers you maybe better off without a Center channel. With my speakers the Center channel restricts the power delivered to my Fronts. My Fronts are capable of bridging the center gap and deliver full power, however my setup uses reflected sound due to my narrow room. So I have the Center channel switched to Off.
  What I'm also doing which you can do as well is I have my balanced outs on the SP2 connected to a Yamaha MG-10 mixer balanced Ins, then connected the balanced outs on the mixer to your balanced ins on your amps. This mixer has low enough distortion .01 so it won't mask the sound, at least I can't tell. The mixer will also give you better control of Line Level, Gain, tone control, volume. And I find the sound quality to be more refined. The mixer is capable of being a pre on its own but coupled with the SP2 I think it sounds great. With the mixer though you only get stereo, I use 2 sets of speakers for 4 channel stereo.
That's all that I can think of at the moment.
Armaegis
« Reply #2 on: 27 Feb 2026, 04:37 am »
There's nothing wrong with using the MCA50 to power only a single centre, but this begs the question... why? are your L/R self-powered?
bcugk
« Reply #3 on: 27 Feb 2026, 01:12 pm »
Fronts are powered by 4BSST via BR20 home theater bypass
GrooveControl
« Reply #4 on: 8 Mar 2026, 04:33 pm »
A 4B in a condo? You are not going to be very popular with the neighbours.  I've only ever used the 4B in PA applications.
