New member/KEF R7 meta upgrade
Pagu38
« on: 21 Feb 2026, 09:04 am »
Hey Everybody... (I couldn't resist).
I'm Patrick (from The Netherlands) and a new member. A long time fan of the You Tube videos from Danny. As a former (mechanical) engineer myself I like the way he approaches these upgrades. At the end of last year I contacted Danny and after a few conversations and sharing my crossover diagram, he sent me some upgrades for my KEF R7 meta. They are finally assembled, in place now and the crossovers (and speakers) are breaking in. As is probably custom, I got the upgrade virus from all the videos and even modified some part before assembling the crossover.
I've captured the whole upgradeproces and in due time can share it here at AudioCircle. As is mentioned in some threads here before, the KEF R-series are extremely braced and there is little room for manouvering or placement. I can tell that a upgrade is not for the faint hearted.
I've read some good advise in other threads on this forum before I began upgrading, so hopefully i can contribute by sharing my own experiences.
Greetings, Patrick.
Re: New member/KEF R7 meta upgrade
« Reply #1 on: 22 Feb 2026, 06:53 pm »
Welcome!
BrandonB
« Reply #2 on: 23 Feb 2026, 02:55 am »
Welcome to the forum.
Danny Richie
« Reply #3 on: 23 Feb 2026, 06:13 pm »
Hey, welcome to AC.
Pagu38
« Reply #4 on: 24 Feb 2026, 05:28 am »
Thanks everybody!
Pagu38
« Reply #5 on: 2 Mar 2026, 08:14 pm »
Back from holiday so I can finally share my findings on upgrading the KEF R7 meta crossover.
Based on the scematics and values (I read from the original crossover for the HF en MF), I got a kit from Danny. After seeing more video’s and realising I was going to do it one time right, I futher upgraded some parts. I got Mundorf mresist resistors and got some miflex bypass caps for the tweeter and midrange. Other parts I was considering were not possible due to restricted space.
To install the board was quit a challenge, but it was succesful bij making a slot to fix it in the back of the cabinet and a screw in the front that can be reached from outside the box. I glued a little piece of plywood in the sidewall so I would be sure the crossover was positioned  right. The shape of the xo-board is deliberated, because you can only move it in about 65 mm before hitting the brace in the middle. The cutouts on the left are necessary to rotate the board counter clockwise and get it as flat as possible to the sidewall. This is necessary to move it inside the speaker. Everything was first simulated in Autocad by measuring all components and the speakers inside dimensions. The layout of the xo board was also determined in autocad. A print was used as a template for drilling the holes.
And like some other comments about the crossovers of the KEF, you have to cut the little standoffs that are used for the pcb (and are glued) and flatten the cabinet on the inside. Also getting the existing wire out is a challenge. They are fixed on two ( not by hand reachable) locations with a tiewrap fixed to a staple in the wall. I had to get a large small rod and losen it.
They boards are in place for about 200 hours now and I realy like the upgrade. I does have another sound signature thought. Instead of a plane with a big spotlights on some instruments or vocals (and the rest somewhat subdued), now there is more a wall of music from left to right with solos or instruments being highlighted (especially good live recordings). It is more a compete “ picture” with things happening all over the place. It also seamed that the old xo is more forward. That makes the music appear more dynamic from time to time (and the new xo laid back) but can also be a bit fatiguing. Stage depth is not altered (as far as I’ve noticed), but my setup/placement is not ideal (speakers 4 meters apart and backside approx. 1 feet from the wall). Detail increased just a little, but in the tweeter circuit was already a reasonable clarity cap. Maybe this could be a future upgrade (other caps then sonicaps for the tweeter?). The vocals are absolutely stunning. No sharp edges at all. The smoothest i have heard with this level of commercial speakers. Probable the result of the miflex bypass caps (?) and for what i’ve read, they still have to break in for a couple of hundred hours.
Only complaint is that the hf/mf seems to be a bit attached from the low frequency. The new xo seems to have less midbase (could this be because the caps measured 98 uF instead of the rated 100 uF ?) and the difference in resolution with the existing low freq. board is (painfully) obvious.Bass appears to be sloppy/boomy. Next fase is to upgrade some parts in the low freq. crossover, connect the new wires correctly to the low xo and mount better binding posts (wbt next gen to make changing types of speakercable possible).
This already a lot of information but if somebody is interested in more info or specific details, just let me know.
NXSTUDIO-DRUMMER
« Reply #6 on: 3 Mar 2026, 12:51 am »
Congrats on your upgrade :thumb:
Before switching out any new parts on your new upgraded crossover, let it settle in first, having some play time.
Typically during the burning in process, the speakers will have different sound characteristics, being the crossover parts are so new. Some days, they can be a little out of balance. After the crossovers get burned-in completely, and they start sounding consistant, then you can determine if it's necessary to do any additional changes, or not.
I had some reservations from time to time with my speakers upgrade, during the burn-in process. Some days they sounded better than other days. However, after completion of burn-in now, I'm absolutely thrilled, how good my speaker sound.
Good Luck!
nlitworld
« Reply #7 on: 3 Mar 2026, 03:54 am »
I'd say a big part of the disconnected sound you're noticing is the upgraded m & t sections are highlighting that the woofer circuit isn't keeping up anymore. Being that your xo has about 200hrs on it, that's most of the way there to burn in those Miflex caps, +/- another 100hrs or so for the last tiny bit. As for the 2uf discrepancy, that isn't large enough to make any discernable change. Might move the xo point a few hz, but nothing of any concern.
Also, if it's possible to bring those speakers a few feet into the room, you'll notice all the depth in soundstage you've been missing. No more "wall of sound" as you'll instead have a "room of music". Those Miflex caps are fantastic at bringing out depth to the music.  :thumb:
Pagu38
« Reply #8 on: 4 Mar 2026, 08:21 am »
Thanks for the feedback. I certainly was planning on getting 400-500 hours on them before a definite evaluation. The low freq. Xo and binding post still have to be modified so that can also have an positive impact. I will also do some setup experiments, but there is less flexibility due to my wife’s opinion about how far they can placed into the room from an aesthetic point of view…... I’ve measured it and the back of the speaker is now 1,6 feet into the room. I can of course determine the sweet spot and place them there when doing solo listening….
