New member.
AudioNewbie
New member.
« on: 19 Feb 2026, 09:36 pm »
Hi everyone! This is my first time assembling anything electrical. I'm usually more of a software guy. I got the nx 3s bravos. I'm kinda of confused about how to wire these up. I tried looking around but I couldn't find a guide for these anywhere. How do I connect the tweeter xo to the woofer xo?
Re: New member.
« Reply #1 on: 19 Feb 2026, 09:41 pm »
The crossover has a polarized output for the tweeter; connect it to the tweeter driver.
The crossover has a polarized output for the woofer; connect it to the woofer driver.
Use solid wire awg 14 or 16.
AudioNewbie
Re: New member.
« Reply #2 on: 19 Feb 2026, 10:32 pm »
Sorry, i'm at the level where I don't even know those terms.
A quick google search didn't help much. Here's my first attempt at the crossover layout with some temporary twists. Do you mean like this?
Re: New member.
« Reply #3 on: 19 Feb 2026, 10:59 pm »
Do Your speaker are a MTM two-way?
Seems the input(amp) are on left and output to the drivers are at right.
AudioNewbie
Re: New member.
« Reply #4 on: 19 Feb 2026, 11:09 pm »
Re: New member.
« Reply #5 on: 19 Feb 2026, 11:45 pm »
Ok. No prob just connect as showed on the image.
Re: New member.
« Reply #6 on: 20 Feb 2026, 11:23 am »
Greetings & Welcome to AC   :thumb:
