BDA3 hdmi inputs
mr_bill
BDA3 hdmi inputs
« on: 12 Feb 2026, 04:04 am »
Hi,
If I buy a Bryston BDA3 can I hook up my tv HDMI earc output into one of the Bryston BDA3’s HDMI inputs to listen to my TVs two channel sound through my stereo?
Bill
Blueshound
  • Matrix Audio Featuring the T10 Active System
Re: BDA3 hdmi inputs
« Reply #1 on: 12 Feb 2026, 03:46 pm »
My listening room and system were originally set up for 7.2 channel use, including a 4K projector and motorized screen. Over time I decided to prioritize my first love, which is high quality 2-channel listening, including changing the Bryston surround processor for a BP-19.
The system includes a BDA-3. The HDMI inputs were a huge benefit, and still are. I still use the projector occasionally for concerts, movies etc. and it works very well. The Oppo blu-ray player has two main HDMI outs, the first is A/V and the second is audio only. Both are connected to the BDA-3, with the A/V providing the video pass-through signal to the projector, and the audio-only provides the audio.
I can also use the Oppo to play SACDs, DVD-A and CDs via the HDMI to the BDA-3, although I rarely do.
The Oppo Audio Only out is labelled just that, not e-Arc. I may be missing something, but I assume they're functionally the same thing.
Brian
skunark
« Reply #2 on: 12 Feb 2026, 10:13 pm »
No the BDA-3 doesn’t support the enhanced audio return channel (eARC) nor does it support the old ARC feature either unless they have made a mid-cycle update
mr_bill
« Reply #3 on: 13 Feb 2026, 12:08 am »
Now I’m really confused.
Maybe James will chime in.
skunark
« Reply #4 on: 13 Feb 2026, 12:42 am »
You can plug components into the BDA3 and have the video sent to the TV, you can’t have the TV send audio to the BDA3 via hdmi, you would need to use the tv optical out if it has one (most do).
HDMI video source  -> BDA3 HDMI video out > TV hdmi will work
TV ARC/eARC audio -> BDA3  won’t work
TV Toslink output -> BDA3 will work
In other words you cannot use streaming apps or the TV hdmi inputs and expect them to route the audio to BDA3 via hdmi.   Read the manual on toslink, my tv limits that to OTA only
The BDA3 hdmi ports are 1.4a so limits 4k to 30 fps.  It’s a little dated
mr_bill
« Reply #5 on: 13 Feb 2026, 05:15 pm »
That really helped clarify, thank you skunark!
