PRA-9X up and running....and WOW!
mresseguie
« on: 11 Feb 2026, 03:35 am »
What a difference adding a preamp to a system makes! [I already knew this years ago, but it never hurts to re-experience it.]
My new PRA-9X is in my system now. It's not even burned in (assuming that's necessary?), yet I immediately noticed a deeper soundstage, greater dynamics, and a more pleasant almost tube-like sound to my music. Well done, Jason!
I can't wait for my new EVO STA-SE to arrive in a couple weeks. Please, please send me the first one, so I don't have to wait any longer!  :lol:
Michael
AllanS
Re: PRA-9X up and running....and WOW!
« Reply #1 on: 11 Feb 2026, 03:55 am »
What else is in the chain?
mresseguie
« Reply #2 on: 11 Feb 2026, 04:25 am »
It's a hodge podge mixture:
Nuprime CDT-8
Nuprime PRA-9X preamp
Holo Spring3 KTE
Class D IcePower 1200AS2
Fritz Loudspeakers Carrera Compact (83.5dB)
While the speakers sound wonderful, their low efficiency demands a powerful amp to do them justice. Initially, I tried 100w/ch and 150w/ch amps only to realize I needed some serious power, which led me to try the Class D amp, which does power them nicely.
rustydoglim
« Reply #3 on: 11 Feb 2026, 06:53 pm »
The Evolution STA-SE is in the league of top tier Class A amps, such as the CH A1.5 (most likely surpassing CH A1.5).
Looks like Evo STA-SE is overkilled for your system  :thumb:
The PRA-9X though is world class, this product is as good as the Nuforce P20 or any other world class preamp.  PRA-9X was over designed and underpriced in the 9 series.  We do not intend to have another preamp in the higher end series due to economic reason (low demand, we can never make a profit). Pairing PRA-9X with Evo STA-SE is ok.
AllanS
« Reply #4 on: 14 Feb 2026, 02:56 pm »
Nuprime CDT-8
Holo Spring3 KTE
I suppose one advantage of multiple residences is multiple spaces needing systems. I’d love to have a reason and place to build a -9 system.
mresseguie
« Reply #5 on: 14 Feb 2026, 11:43 pm »
Jason,
I experienced an odd very loud static-like sound (through the speakers) when my PRA-9X is in variable mode. I tried rearranging my gear because I initially thought it was wires and cables not getting along. Then, I moved my system into my tiny home office hoping that would solve the issue, but it persisted. Finally, I switched my preamp to 'fixed', and everything seems to be fine now. I control the volume either from my DAC's volume control or from my computer.
What is it about the preamp's variable setting that causes such interference? [I'm mystified.]
Edit:
The cabling in the above issue was silver XLR cables from my DAC to the preamp and copper RCA cables from the preamp to the amp. [This is the combination that sounds best to my ears in my main rig in Oregon.] Thirty minutes ago, I switched out the silver XLR cables with copper XLR cables,  and the crackling/static sounds are gone.  :thumb: I'm once again happily using the variable setting on the preamp.  :banana piano: :dance:
Michael
« Last Edit: 18 Feb 2026, 03:13 am by mresseguie »
rustydoglim
« Reply #6 on: 20 Feb 2026, 02:13 pm »
Bad cable?  There are all sorts of possibilities and I get this kind of questions from time to time.  There is no way I can remotely figure out  :lol:
My answer: I don't know.
The fixed and variable setting is explained on page 12 of the manual.
