cant login
F B Pearce
  • Guest
cant login
« on: 28 Jan 2026, 07:31 pm »
I get a respone: "we need to run a routine email check..." It alsop says it will send a code but I don't receive a code.
F B pearce
  • Guest
Re: cant login
« Reply #1 on: 31 Jan 2026, 02:15 am »
Hello, still unable to get in. Maybe my account has a previous email address and nor receiving the email?
Re: cant login
« Reply #2 on: 31 Jan 2026, 02:23 am »
The code is sent immediately to your registered email address.
A few days a go I had received the code email in about 5 seconds.
« Last Edit: 31 Jan 2026, 11:01 am by FullRangeMan »
Re: cant login
« Reply #3 on: 31 Jan 2026, 02:26 am »
Well this is not AC fault.
If your email address is outdated the AC can not know or inform you.
The system will send the email code to the registered email you informed.
« Last Edit: 31 Jan 2026, 12:58 pm by FullRangeMan »
FB Pearce
  • Guest
Re: cant login
« Reply #4 on: 31 Jan 2026, 02:13 pm »
I’ve got no access to the old email. The firm above asks for my email and input on the current address can I get a code sent to the new email. If not should I just open a new account?
Re: cant login
« Reply #5 on: 1 Feb 2026, 12:01 am »
Members can not have two accounts.
For recovery email please wait the Admin.
owner at GR Research
  • Guest
Re: cant login
« Reply #6 on: 2 Feb 2026, 11:51 pm »
I am having the same problem. I do not receive a code to my email either.
  • Guest
Re: cant login
« Reply #7 on: 3 Feb 2026, 05:28 pm »
I still can't login and I do not get sent a code to my email.
[email protected]
F b Pearce
  • Guest
Re: cant login
« Reply #8 on: 4 Feb 2026, 09:04 pm »
Hello, still no email to reset password
ServerAdmin
Re: cant login
« Reply #9 on: 5 Feb 2026, 04:10 am »
There is no account with the username or email you have provided.
ServerAdmin
Re: cant login
« Reply #10 on: 5 Feb 2026, 04:11 am »
The mail server logs shows that the password reset email was delivered. (Multiple times.) Please try again and check your spam/junk etc.
