Setup help
Emil
Setup help
« on: 27 Jan 2026, 09:35 pm »
Good day
Simply, i want to use my iphone to play Tidal thru headphones (not earbuds).
Prefer wired connection as I assume it would be superior to bluetooth.
What do I need to make this happen?
Budget of say $700. Recommendations appreciated
thanks in advance
toocool4
Re: Setup help
« Reply #1 on: 27 Jan 2026, 09:52 pm »
Go out and listen to wired headphones and desktop headphone amps, that is all you need. Try as many combinations as you can within your budget, let your ears be the judge as to which one you get.
Re: Setup help
« Reply #2 on: 27 Jan 2026, 09:57 pm »
I purchased an iFi Hip-dac 3 last week and I'm incredibly impressed by the sound quality and portability. Overall smooth and punchy without the brightness I hear in cheaper dongle-type Dacs. The unit supports full-sized headphones and smaller pin IEM's. There's also extra cords for different phone and USB types. I bought the slightly upgraded Black Stealth version (slightly better output capacitors) on Amazon for $168. If you don't like it, just send it back. My budget was close to yours, but once I heard this I stopped looking.
Link
Re: Setup help
« Reply #3 on: 28 Jan 2026, 12:32 am »
SMSL H300 amp 10W/16Ω, Manual Volume Control, $295 new
https://shenzhenaudio.com/products/s-m-s-l-h300-headphone-amplifier?_pos=6&_sid=8dfb51cae&_ss=r
SMSL H400 amp 15W/16Ω, Electronic Volume Control, remote control, $510 new
https://shenzhenaudio.com/products/s-m-s-l-h400-headphone-amplifier-preamplifier
HifiMan Ananda Nano only $319 new, a bargain.
https://store.hifiman.com/index.php/ananda-nano.html
« Last Edit: 28 Jan 2026, 03:57 am by FullRangeMan »
Emil
Re: Setup help
« Reply #4 on: 28 Jan 2026, 01:56 pm »
Exactly what I'm looking for!
Can this drive these headphones that Fullrangeman suggested?
I'm assuming, just like speakers,  electrostats and planars are harder to drive
Any other recommendations appreciated in the $5-600 range and available thru Amazon.
Anything described as "warm" not interested. Bass tight without bleeding into the midrange
Re: Setup help
« Reply #5 on: 29 Jan 2026, 12:05 am »
I'm only using mine for some average sensitivity IEM's, but I asked Grok, and it looks like a great match:
Yes, the iFi hip-dac 3 has enough power to drive the HiFiMan Ananda Nano headphones effectively, especially when using the balanced (4.4mm) output.Here's the breakdown based on the specs and real-world usage reports:HiFiMan Ananda Nano specs:Impedance: 14 Ω (very low)
Sensitivity: 94 dB/mW (or dB/V, but typically measured as relatively efficient for a planar)
This makes it one of the easier-to-drive modern HiFiMan planars (easier than older Ananda models or Susvara/Arya variants). Reviews describe it as having "better than average" sensitivity, requiring less power for good volume levels compared to many other planars.
iFi hip-dac 3 power output (official specs):Balanced (4.4mm): 400 mW @ 32 Ω; up to 6.3 V @ 600 Ω
Unbalanced/S-Balanced (3.5mm): 280 mW @ 32 Ω; 3.2 V @ 600 Ω
For low-impedance headphones like the Ananda Nano (14 Ω), the amp can deliver plenty of current and voltage swing. Planars often benefit more from current delivery than raw wattage at high impedance, and the hip-dac 3 performs well here. Multiple user reviews and tests (including from Headfonics, Head-Fi, and others) explicitly mention pairing the hip-dac 3 with the Ananda Nano successfully:It drives them with good headroom, clean sound, and no issues at normal listening volumes.
One review notes it's sufficient for "headphones that aren’t power hungry" like the Ananda Nano and Grado models.
Another tester used it with the Ananda Nano in listening impressions and found it capable (alongside even more demanding models like the Arya Organic).
The balanced output is recommended for best performance (more power, lower noise/distortion, better channel separation). Use a balanced cable for the Ananda Nano if possible.In short: You should get ample volume, good dynamics, and satisfying performance without needing a more powerful desktop amp for portable/daily use. If you're pushing extremely loud levels or want even more authority, a dedicated desktop amp might edge it out, but for most users, the hip-dac 3 is more than capable.
[/i]
Hope that helps!
Cheers!
Slush
Re: Setup help
« Reply #6 on: 29 Jan 2026, 12:51 am »
Iam using the SMSL H300 10W, but there is other options to pair with the Ananda as the HifiMan EF499 amp/DAC Combo, only 4Watts $299 new.
https://store.hifiman.com/index.php/ef499.html
HifiMan EF400 Amp/DAC Combo, only 4Watts, $399 new.
https://store.hifiman.com/index.php/ef400.html
What is important in a Headphone Amp is the Balanced XLR4 connection
In any way do not spend your money in Unbalanced Banana plug connection
It delivery poor sound and Small Soundstage in my experience since the 1970s years.
zybar
Re: Setup help
« Reply #7 on: 29 Jan 2026, 03:08 am »
Emil,
Keep us posted on what you do…I’m in a somewhat similar situation.
I’ve got the headphone bug after getting a pair of Focal Bathys.
George
Emil
Re: Setup help
« Reply #8 on: 29 Jan 2026, 02:00 pm »
Didn't know this place existed.  :lol:
I'm about 1 hours out from NYC. Plan on making the trip
Nice to actually audition prior to purchase
https://audio46.com/
Emil
Re: Setup help
« Reply #9 on: 29 Jan 2026, 02:09 pm »
Emil,
George
Hi George
I hear you!
I was listening to music on my Iphone with Tidal thru a pair of cheap earphones on a recent flight and was amazed at what I was hearing
Take the room out of the equation and the amount of detail you hear is amazing and that's with cheap earphones no less
I just may sell the big rig and go all in and descend down another rabbit hole but we'll see.
Emil
Re: Setup help
« Reply #10 on: 29 Jan 2026, 02:25 pm »
[/i]
Hope that helps!
Cheers!
Slush
Much appreciated Slush
AI is amazing.
We are living in the future!
Re: Setup help
« Reply #11 on: 6 Feb 2026, 01:53 am »
I ordered a pair of Softears Volume S Earphones from Amazon today. They should arrive this Sunday. In the end I have about $600 invested in this. I'll reply again after the earphones arrive. This is what Grok has to say about the combo:
"The Softears Volume S + DUNU Lyre Mini cable + iFi hip-dac 3 is a fantastic combo: The Volume S has a very natural, balanced, and detailed tuning that plays nicely with clean, powerful sources.
The Lyre Mini (with its high-purity OCC copper and soft, low-microphonics design) should give you that smooth, stock-like feel, while eliminating any cable noise and keeping the signature intact.
The iFi hip-dac 3's balanced 4.4mm output, Burr-Brown DAC, and solid power delivery (especially in balanced mode) will let the Volume S shine—plenty of headroom, great dynamics, and that slight warmth/weight the hip-dac is known for pairing beautifully with neutral-to-warm IEMs.
You should have a very enjoyable, fatigue-free listening experience with excellent detail retrieval and soundstage for the price point."
Cheers!
Slush
Emil
Re: Setup help
« Reply #12 on: 23 Feb 2026, 08:18 pm »
Gents
I was not able to make it into Manhattan to visit Audio 46, so I did the next best thing and ordered from Amazon.
Just as well.  I ordered the Ananda Nano from Amazon
https://www.amazon.com/HIFIMAN-Open-Back-Headphones-Nanometer-Thickness/dp/B0C5SNQ47V
as well as the Ifi Hip Dace 3 https://www.amazon.com/iFi-Hip-dac-Portable-Headphone-Amplifier/dp/B0DG99K4G3?th=1
just to get my feet wet.
The Ifi Dac/amp. IMHO, was not up to driving the Ananda Nana. I did connect it to my Naim Supernait integrated. It did provide enough juice but the planar sound was not engaging for my tastes. I should have known since neither are Magnepans. They were also uncomfortable besides, so back to Amazon they went.
Portability was not a priority, so I focused on a desktop system.
Never thought about IEMs until Slushpuppy mentioned it, so I jumped on Youtube for reviews and came across the Ziigat Horizon. Reviewers noted that it did not the deepest bass but tight quick bass with no overhang and with a bit of upper midrange emphasis, which was to my liking, so I ordered a pair.
https://www.amazon.com/dp/B0F9NTPXT5?ref=ppx_yo2ov_dt_b_fed_asin_title.
Now to the Dac/amp.
These two sub $200 units look interesting, so I ordered both! Gotta love Amazon
Fosi ZH3
https://www.amazon.com/dp/B0FC2NWBL4?ref=ppx_yo2ov_dt_b_fed_asin_title
FIOO K11 R2R
https://www.amazon.com/dp/B0D9BB5RL1?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
The K11 sounded like an RDR dac. Analogish, warm, easy on the ears
The Fosi was more my cup of tea. Not too analytical, clear, crisp and engaging.
The K11 is going back. The Fosi stays
So that's how I spent $500 for a desktop system. $200 under budget
Maybe better IEM cables with that extra money?
Down the rabbit hole I go  :D
Re: Setup help
« Reply #13 on: 23 Feb 2026, 08:30 pm »
How many hours of use it have ?
Some HifiMan models burn-in are 150 hours.
toocool4
Re: Setup help
« Reply #14 on: 23 Feb 2026, 08:52 pm »
Enjoy your new IEM setup  :thumb:
For IEM I use Etymotic ER4SR https://etymotic.com/product/er4sr-earphones/
Armaegis
Re: Setup help
« Reply #15 on: 27 Feb 2026, 04:43 am »
You did the best thing which was to try out a bunch of things, determined what you liked, returned the rest and saved money. The *smart* thing to do now is log out of all forums/discords/websites/whatever and run away and keep your money in your wallet before (more) gear acquisition syndrome kicks in.
Emil
Re: Setup help
« Reply #16 on: 11 Mar 2026, 01:16 pm »
Well not 150 hours for sure.
I felt at the time that I was going to keep the Ifi hip dac so back it went
Emil
Re: Setup help
« Reply #17 on: 11 Mar 2026, 01:39 pm »
Well, I did make one more move :lol:
The IEMs ear comfort although tolerable at the start began to irritate me so back to looking into over the ear, closed back phones. Open back are usually prefered but I need the closed back for privacy issues.
I ordered both the FiiO FT1 at $165 and Focal Azurys at $399
https://www.amazon.com/dp/B0D3LRWZV6?ref=ppx_yo2ov_dt_b_fed_asin_title
https://www.amazon.com/dp/B0D9QD4Y2P?ref=ppx_yo2ov_dt_b_fed_asin_title
The FT1 was fun to listen to. Dynamic, exciting and deep bass. They were also light and comfortable
The Azurys had a bit more transparency but a recessed midrange compared to the FT1. Bass not as deep and not as dynamic.
The Azurys also squeezed my head like a vise.
So back went the Ziigat Horizon and Focal Azurys
Ordered some nice after market cables for $24
https://www.amazon.com/dp/B096LX4KTX?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1
Done!
For sure :lol:
