Industry Circles
Bryston Limited
Idle current of Cube-series amps
jeffreybehr
Volunteer
27 Jan 2026, 07:22 pm »
What are they? And by 'idle', I mean fully turned on but not playing anything.
jeffreybehr
Volunteer
Re: Idle current of Cube-series amps
28 Jan 2026, 08:28 pm »
Per Bryston--a single 7B3 consumes about 100 watts at idle.
Then--
(0162010) Mike Pickett (administrator) - 2026-01-28 14:55
https://mantis.axiomaudio.com/view.php?id=146584#c162010
Hi Jeffrey,
The 28B3 consumes around 200 Watts at idle. Both units will deliver some power in class A, but it's a relatively small amount and difficult to measure. As a guess, it would be around 10 Watts for the 7B3 and 20 Watts. The reason that this is difficult to measure is that there is no change in the performance of the amplifier, including THD+N and IMD, when it switches to class AB.
Mike"
And FWIW and as I understand it, his use of "switches to class AB" is not exactly accurate, as nothing in the amp does any switching.. A more accurate way to say that would be 'eases into class-AB operation'.. Nelson Pass has written fairly often about this; here is one I found quickly and probably is worth reading.
https://www.firstwatt.com/wp-content/uploads/2023/12/art_leaving_class_a_2019_redux.pdf
So for MY situation, a 7B3 draws only 27% of what my Pass XA60.8 draws* at idle and about the same as a 110watts-into-8 Linear Tube Audio model Century that I'm fantasizing about.
* and even a 28B3 draws at idle only about half of what that XA60.8 draws.
Last Edit: 9 Apr 2026, 10:34 pm by jeffreybehr
Stefan_DR3
Reply #2 on:
1 Feb 2026, 05:45 pm »
This information was put in the user manuals, but they are known to have typos, so good that you checked with Mike.
Industry Circles
Bryston Limited
