No-Rez
ldmlholmes
No-Rez
« on: 24 Jan 2026, 09:26 pm »
Anyone had any trouble getting No-Rez to stick over Duratex?
Peter J
  • Hmmmm
Re: No-Rez
« Reply #1 on: 25 Jan 2026, 09:38 pm »
Can't say I've had the problem, but I can see a couple of issues that could crop up.
1.Texture. Any textured surface is only capable of bonding on the high points with peel and stick adhesive, so not a very intimate bond.
2. Most water-based coatings (latex) have a long cure time and even when fully cured have a somewhat flexible nature. Not a great starting point for adhesion. I don't know if this is true of Duratex, but many acrylic house paints exhibit something called "blocking" which manifests as a kind of perpetually sticky surface, which you'd think would increase adhesion, but it I suspect dissimilar adhesive probably don't respond it that way.
Maybe if we knew more about your particular situation, we could better identify problem.
Danny Richie
Re: No-Rez
« Reply #2 on: 28 Jan 2026, 06:39 pm »
So long as the surface isn't dusty, it'll stick.
