Log In Problem
0 Members and 1 Guest are viewing this topic. Read 1008 times.
David Morasco
  • Guest
Re: Log In Problem
« Reply #20 on: Yesterday at 12:34 am »
On January 14, I used the "Forgot Password" page to change the password I had been using.
I just tried to log in with this recently changed password and I got the same message/screen:
•   Login
An Error Has Occurred!_____________________________________________________________
That username does not exist._______________________________________________________
        Back
I am not optimistic that changing the password again will fix this.
David Morasco
  • Guest
Re: Log In Problem
« Reply #21 on: Yesterday at 03:08 am »
I changed the password.  I later logged out and then tried to Log In.  Exact same error message as in my previous post (12:34 am).
For quite a while now (when I was able to log in), I have had to log in twice. The 1st time it says Incorrect Password.  The second time, using the identical password, it lets me in.  I had inquired about this when it first happened and I did not hear anything back.  I just kept logging in twice - until this latest issue.
I have changed the password twice and this has not fixed the issue.  Clearly with the dual log ins and the error message (which is incorrect - the username does exist) there is something else wrong.
ServerAdmin
Re: Log In Problem
« Reply #22 on: Yesterday at 08:11 am »
To clarify : after changing the password, you were then able to log in?
