Somethings wrong
0 Members and 1 Guest are viewing this topic. Read 1296 times.
DecibleDude
Somethings wrong
« on: 6 Jan 2026, 12:39 am »
I was unable to post two quite lengthy things today and lost what I wrote.
Re: Somethings wrong
« Reply #1 on: 6 Jan 2026, 12:51 am »
There is a period of time before your browser Time Out occurs.
Then would be recommended type the text and corrections in a text editor such as WordPad or Note Pad to not lose the typed text.
DecibleDude
« Reply #2 on: 6 Jan 2026, 02:02 am »
Thanks for the info. I don't think I'll be going down that road again. In the future it'll just be short and to the point. Although I think I've posted quite lengthy things in the past without problems, but possibly not as long as today.
brooklyn
« Reply #3 on: 6 Jan 2026, 02:26 am »
I always write any comments I post on this or any forum on my computers
Text Edit app. This way I can keep or delete it as I chose after I post it..
« Reply #4 on: 6 Jan 2026, 02:47 am »
In the past I used to type texts in the WordPad, but now I changed to just copy the full text after its done with Control+A and Control+C and then enter/post, very simple.
AllanS
« Reply #5 on: 6 Jan 2026, 02:55 am »
I’ve had the same happen to me in other forums.  If not creating in a separate text editor I’ll copy my response before hitting post.
Rusty Jefferson
« Reply #6 on: 6 Jan 2026, 04:49 am »
Did you recently log in? There is a box to check if you want to stay logged on otherwise I believe it times you out.
« Reply #7 on: 6 Jan 2026, 08:04 am »
The default logon time are 60 minutes,
it can be extended to 999 minutes.
Letitroll98
  • Too loud is just right
« Reply #8 on: 6 Jan 2026, 11:56 am »
Always remember the online admonition, TLDR.
DecibleDude
« Reply #9 on: 6 Jan 2026, 12:04 pm »
That's interesting, perhaps I'll try that for a third try today.
DecibleDude
« Reply #10 on: 6 Jan 2026, 01:31 pm »
Well, I just had success posting my story by checking the box saying stay logged in, and whether that's the reason for success, or the fact that I raced through the story making it far shorter and I suspect less entertaining it at least conveys what might be useful info for others.
