For bananas, the only really good ones are pure copper and because of that they need to be locking,
Anticables, for example, sells gold-plated beryllium copper BFA connectors for $30 for a set of four. https://anticables.com/store/Banana-Plugs-Set-of-4-p103033872These BFA connectors seat very securely without being locking and are not expensive.GR Research sells a set of four pure copper tube connectors for $59. These also seat securely without a locking mechanism (other than the friction of the connector). They do require the matching tube connector female to be installed into the speaker, however, so they are most commonly used when building your own speaker although they could technically be retrofitted to any loudspeaker as a DIY project. https://gr-research.com/product/electra-cable-tube-connectors/
“friction fit wears through plating”It might if you are constantly unplugging and replugging, but seriously, do you really think this would be an issue for most people?
I've been using high quality banana speaker connectors for a long time without issue.. That said, according to Cardas Audio there is more contact area with spades..
bare wire is still the best
+1.I didn't want mention the real truth to fans of audio gadgets.The more connections worse, more signal losses.
