Introduction?
0 Members and 2 Guests are viewing this topic. Read 1333 times.
bill cart
Introduction?
« on: 28 Dec 2025, 03:50 pm »
This site is way too complicated for a moron like me. It took me 20 min to get the registration to work. Never seen a help site so hard to use. I would understand 2FA but this constant verification is too much to deal with. Hey I am 77 and stupid which is why I need a little help, OK? Don't really understand the reason for all this constant verification crap. Just looking for a little help from someone from gr-research which I was promised in their videos.
I have the Klipsch RP600M speakers and have bought the updated parts from gr-research. I was able to get the rear port off. I got the screws out of the speaker connectors but I can't get that out because of circuit board on the back of it. I can't get the woofer out because I don't know what type of tool I need to remove those screws. They are not the same as the ones on the back port. I can't proceed any further until I can get the woofer out. Can somebody please explain to me what I need to get those screws out without wrecking the speakers? They don't seem to be Phillips head , star, square or hex. Why was this not in the video?
Danny Richie
Re: Introduction?
« Reply #1 on: 29 Dec 2025, 03:02 pm »
Once you've made two approved posts then your post are seen as soon as you make them and you get full access to the site without issues.
If I remember correctly, you just tilt it forward a little and slide it out. It may be hanging on the connection to the drivers though. You will need to remove them first.
Just a standard Allen wrench.
goggle1824
Re: Introduction?
« Reply #2 on: 29 Dec 2025, 06:24 pm »
Hi Bill, Welcome to AC (Audio Circle).
In addition to Danny helping you with your project, there are others here who may have completed the same project.
I share that because an additional avenue for assistance is “Starting a New Thread” and asking for help or insights with your project.
This place is chocked-full of super-helpful and very well informed members! I know personally, I continue to learn interesting stuff here.
Again, Welcome!
bill cart
Re: Introduction?
« Reply #3 on: 31 Dec 2025, 12:44 am »
The screws are 3mm allen head. I found the answer on the Klipsch forum with a google search. I had to dig around to find one as I don't use my metric set often. I have completely disassembled the first speaker, scraped up a lot of glue and started installing the Nores. The kit had 3 sheets but I needed 2 of them for the first speaker. Guess I have to order a full sheet, I don't see the option for a half sheet which these appear to be I think. On this speaker there are no braces on the bottom so I started from there and went up to about an inch from the top. There are braces on both sides so I cut pieces to fill the flat space. I used the left over part for the top and a bit for the back. It looks good, I just don't have enough to do the other speaker the same way. Guess I used more than I should have? It looked like I did not need the nores in the parts along the side where the braces are. It took a while to figure out what size and shape to make the nores but it looks like it should be good. I don't hear much when I knock on the sides.
