BDP-3 set-up bafflement
dubkarma
  • "God made man because he loves stories." - Canetti
« on: 27 Dec 2025, 07:32 pm »
Just set up a new (for me) BDP-3 streamer.
I've connected the BDP-3 to my LAN via Ethernet on one end and to a BDA-3 DAC via BNC SPDIF on the other.
The DAC outputs to a BP-26.
Then I named and activated the new BDP-3 in the Roon control software.
The operating lights show the Ethernet connection to the BDP-3 is active and the BDA-3's lights shows a lock to the input from the BDP-3.
The only issue is that when I play a track, I get no sound from the audio system.
So far as I can tell, everything is set up as it should be, so I am somewhat baffled at what to try next.
Any suggestions would be most appreciated!
Thanks! Joel.
RGunner
Re: BDP-3 set-up bafflement
« Reply #1 on: 27 Dec 2025, 10:15 pm »
Can you see the BDP-3 from a web browser on your local network?  Play a file maybe then?
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #2 on: 27 Dec 2025, 11:17 pm »
Thanks! Joel.
Joel - send Adam an email - [email protected]
jobiwon
« Reply #3 on: 28 Dec 2025, 11:59 pm »
Yeah if you can get to the BDP via a Browser set the play mode to MPD and see if you can login to your Music service and stream.
