Questions about driver placement on baffle for MTM using Heil AMT
0 Members and 1 Guest are viewing this topic. Read 4553 times.
tomlinmgt
I just picked up four of the Eminence Beta 8's that Madisound has on sale to try with a pair of NIB Heil (ESS) AMT's and other divers I already have. I was thinking maybe I'd try them in an MTM configuration with the Beta 8's playing down to around 250 Hz where I'd let a bass driver (either a JBL 2226 or Acoustic Elegance IB-15) take over to bridge between the  Beta 8's and my GR Research Triple Threat open baffle servo subs using either an active crossover (I have Rane AC-23 and Ashly 2001 ) or MiniDSP 2X4 HD to get transitions between drivers sorted out..
My question is...for the baffle area where the MTM will be situated, what might be the best way to locate the drivers on the baffle and what might I consider for wings? I owned GR Research x-Statiks at one time and those configure the MTM with no offset for the tweeter or mids and use no wings on a narrow baffle. Danny says the issues that this configuration typically will create (dipole hump and baffle edge artifacts, I assume) are compensated for in the networks...but that with models like the NX-Otica and NX-Treme, the use of side wings largely negates the need for electronic compensation. But I still wonder how he avoids the baffle edge artifacts with a centered tweeter.  Is it because he uses a waveguide...which I assume controls dispersion and directs energy away from the baffle edge?  And if so, would it be the same for the Heil AMT since it has a sort of waveguide in its design?
A second question is about driver spacing. I'm a bit of a newbie with this stuff, but my understanding is that in a D'Apolitto array, the center to center distance between mid drivers should not exceed the wave length at crossover frequency. So if I have a pair of 8" drivers and the height of the Heil AMT is 6", that's around 14-15" with drivers clustered together as tightly as is physically possible...which would necessitate a crossover frequency in the 900-975 Hz range
..which is a bit lower than I was hoping for. Hopefully someone will point out that my calculations are wrong and I can push that crossover frequency up a bit higher, lol.
As I said, I'm a bit of a newbie with speaker DIY, but have built a few open baffles before including a PAP Trio clone using Tang Band 1808 and Alpha 15a's, and my first OB build used Beta 12LTA and BG Neo3 on top of Alpha 15a in an H-frame...so I'm not flying totally blind. I'm a fairly competent woodworker and my listening space is large and very well treated for acoustics. Really, I'm just wanting to have some fun and maybe wind up with something noteworthy I can call my own creation.
Jon L
Having played with six AMT Heil's, whatever design you end up, I would strongly encourage the use of stacked Heil's.  The improvement in sound quality, sensitivity, ability to play loud and cross over lower takes great speakers to fantastic ones.  They happen to be on sale again  :thumb:
planet10
  • Frugal-phile (tm)
    • planet10-hifi
get the drivers as close as possible. You will still be quite far away from the optimal less than quarterwave centre-to-centre distance.
dave
tomlinmgt
dave
Seems I read somewhere that the further you sit from the drivers, the less critical that spacing becomes as it gives the drivers space to blend. Is that accurate?
Yes this is correct, but hardly a solution in modern houses.
I very sorry you have not used an coaxial driver to not need use an complex D`Appolito crossover
Beyma are plenty of 8'', 12'' and 15'' coaxials with hi efficiency.
Beyma:
8BX  BR box 60L
12CX  BR box 100L
12KX  BR box 100L
12CXA400Nd
15XA38Nd
15CXA400Fe
15DX  BR box 180L
15KX  BR box 150L
Also check the new Xizi Lii Audio H2102 Coaxial.
planet10
  • Frugal-phile (tm)
    • planet10-hifi
Simple geometry. The relative differences of the drivers in wavelengths they produce becomes smaller, so less critical. Oe of the reasons a desktop monitor with a singlr driver.
dave
tomlinmgt
Quote from: FullRangeMan li I'll my
15DX  BR box 180L
15KX  BR box 150L[/b
5
I'm no stranger to coax drivers (I have Altec 604-8G's).  I'll do up an open baffle using a coax driver someday. But I want to try the Heil AMTs that have been sitting on the shelf for a few years now...and have really enjoyed every MTM design I've owned or have listened to.
5
These drivers I mentioned need a BR enclosure, dont work on OB.
tomlinmgt
Yes, I've read about the merits of stacked Heils. I'd certainly be interested in exploring that concept one day, but for this initial build I'd like to hear what a single unit is capable of when implemented in an MTM.  I mean, the PAP Trio Tens get very good reviews.  I'm hoping to do something similar, but have the mid-bass drivers playing mids only.
jk@home
I'm eventually going to add Heils to my OBs, but working on subs for the system right now. Also have two pairs, but man that's a lot of weight for a OB baffle. So sticking with just one per side as for now. A couple things, make sure the Heils are at or close to ear level, as they have limited vertical dispersion. And if you are going to use any active crossover (even just temporary) it is recommended to have a protection cap and fuse in line of the drivers.
I also bought two pairs of the Madisound Beta 8s to try later (what a deal!), in my case was thinking of a 1-1/2 way setup for two per side. But right now my bass drivers are being driven by Dayton plate amps, that have a ceiling of 180 Hz. A little low for the 8" midrange. So that's a later.
Rusty Jefferson
You could probably take some inspiration from this Pure Audio Project speaker. The audioxpress article is available for download at the bottom of the page.
https://audioxpress.com/article/fresh-from-the-bench-meet-the-pureaudioproject-trio15-heil-amt-speakers
