Denon tape cassette, DR-M10
0 Members and 1 Guest are viewing this topic. Read 84 times.
rif
  • Not a cowboy
« on: 9 Dec 2025, 10:48 pm »
$150
It was a very good tape deck at the time, and holds its desirability today.
It hasn't been used in a few years, but I tested it as much as I could, I don't have any cassettes. Unit Lights up, Play, FF, REW, etc... spin the motors.
The cloudiness on the front deck mechanism is a photo artifact - its not really there.
Some scratches shown in the pictures due to normal wear and tear from moving houses and room locations a few times.
Please see my other ads for a Luxman receiver that pairs well with this deck.
3 motor silent mechanism
Auto tape select
Dolby B and C
Normal, CrO2, Metal
Tape Counter
Peak Level,Meter
Input level, fine bias adjust, output level
Headphone socket
Technical specs
Type: 2-head, single compact cassette deck
Track System: 4-track, 2-channel stereo
Tape Speed: 4.8 cm/s
Heads: 1 x record/playback, 1 x erase
Motor: 1 x capstan, 1 x reel, 1 x mechanism
Tape Type: type I, CrO2, Metal
Noise Reduction: B, C
Frequency Response: 35Hz to 17kHz  (Metal tape)
Signal to Noise Ratio: 70dB  (dolby C)
Wow and Flutter: 0.05%
Input: 77.5mV (line)
Output: 0.775V (line)
Dimensions: 434 x 115 x 286mm
Weight: 5kg
