Uberbuss questions
0 Members and 1 Guest are viewing this topic. Read 14915 times.
SoCalWJS
Re: Uberbuss questions
« Reply #20 on: 10 Dec 2025, 03:56 am »
Just throwing in my 2 cents…..
I’ve had an UberBUSS for a long time. Good stuff.
I will always remember the one time I took it to a friends house and we plugged everything into it. Older house with less than stellar wiring. Was really good.
Then it was time to leave and we unplugged everything. The difference was so obvious. Begged me to leave it.
jtwrace
    • TIPP YouTube Channel
« Reply #21 on: 10 Dec 2025, 02:53 pm »
A few days ago, on another audio forum, Dave posted this: "The BUSSes never had MOVs, unless my customer requested them."
Danny, is surge protection an option customers can request?
I knew there was a device that he built with MOV's.
https://www.audiocircle.com/index.php?topic=106485.0
Danny Richie
« Reply #22 on: 10 Dec 2025, 04:53 pm »
This version has no MOV's and is not designed for surge suppression.
Also regarding how it is potted. The potting material is a fire retardant material to eliminate damage from lightning strikes.
dflee
« Reply #23 on: 10 Dec 2025, 06:01 pm »
Danny:
Would love to see you take on the whole BUSS series.
I love my digital version.
Don
mlundy57
« Reply #24 on: 10 Dec 2025, 06:47 pm »
Danny:
Don
+1  I also have a Digi BUSS and like it. I have the media server and network switch for the music room plugged into it.
Mike
Huskerbryce
« Reply #25 on: 10 Dec 2025, 07:50 pm »
I will probably need to order and try an UberBuss on my system now.  The never ending quest for better always gets me excited to spend more money.   Has anyone ever directly compared an UBerBuss to a Furman elite 20 amp conditioner?  I own the latter.  I wonder how much more performance is gained/lost comparing power from the Furman vs an UberBuss?  🤷🏼‍♂️.
RonP
« Reply #26 on: 10 Dec 2025, 11:52 pm »
I went from a Furman PL-8C 15 Amp (lower end model vs what you mentioned) to an UberBUSS.  Not going back.
Nick B
« Reply #27 on: 11 Dec 2025, 06:45 am »
Glad this is all settled. The UberBUSS is the "bee's knees" of power conditioners. It is the foundation piece of my system. Glad it will continue to be offered and by GR Research!
YEEEEGZ
« Reply #28 on: 11 Dec 2025, 03:36 pm »
I'm assuming you can plug the Uberbuss into something like an APC UPS to act as a surge protector/backup power incase of brownouts/power loss?
corndog71
  • Some people call me Rob.
« Reply #29 on: 11 Dec 2025, 06:30 pm »
Since it’s not strictly patented, one modification that might be beneficial would be to add a hydraulic electromagnetic breaker like Shunyata uses on their power strips.
From Shunyata’s description:
Over-current protection is a requirement for today’s high current audio power distributors. The vast majority of manufacturers use an inexpensive thermal fuse or breaker. Both are specifically designed to heat up as the current level rises. This causes voltage drops, increased contact impedance, thermal noise, excessive heat generation and current limiting effects.
There is a better solution — the hydraulic electromagnetic breaker that utilizes low-impedance relays and a sensing coil that reads the current level without heating up or limiting current. They can operate right up the to the maximum current level without heating up or limiting instantaneous current. They are rarely used in competitive products since they cost 10-20 times that of a common fuse or thermal breaker.
Added cost is the only downside.
Danny Richie
« Reply #30 on: 12 Dec 2025, 10:32 pm »
Plugging the Uber into a UPS is not recommended.  UPS devices are inherently nasty in waveform.
Panel mount surge protection circuit breakers are available in both 15A and 20A from Square D, Siemens, Eaton, GE, etc...  Absolutely silent, much better than MOVs...
Home Depot, Lowe's, Menards, Amazon...
BrandonB
« Reply #31 on: 13 Dec 2025, 12:43 am »
Danny can you do a Tech talk on the electrical side of your new room from the grid to the room?
YEEEEGZ
« Reply #32 on: 13 Dec 2025, 02:17 am »
OK, good to know! Thank you, Danny.
Danny Richie
« Reply #33 on: 13 Dec 2025, 03:57 pm »
I don't think that I can fill up much of a video with that. It would take about a minute to go through.
Cappy
« Reply #34 on: 14 Dec 2025, 06:03 pm »
I have a P.I. Audio Group UberBuss that has developed a buzz.  No components need to be plugged in to get the buzz.
Works great, otherwise.
Any idea what the buzz could be from and if it is fixable?
Danny Richie
« Reply #35 on: 14 Dec 2025, 06:34 pm »
You likely have DC on your lines.
Early B.
« Reply #36 on: 14 Dec 2025, 07:32 pm »
Cappy -- plug your Uber into this device and see if the buzz goes away:  https://avahifi.com/collections/accessories/products/humdinger-dc-line-blocker
Rusty Jefferson
« Reply #37 on: 14 Dec 2025, 07:42 pm »
I was under the impression the audio system in his room is run on battery power, eliminating the grid power as an issue?
Cappy
« Reply #38 on: 14 Dec 2025, 08:35 pm »
Thanks guys.  I do in fact have DC on my lines, measurable with my voltmeter.  It gets worse when the heat pump is on, which is much of the time in the winter.
I just plugged the UberBuss into a Puritan power conditioner which blocks DC, and voila, buzz is 95% eliminated.
NIGHTFALL1970
« Reply #39 on: 15 Dec 2025, 12:12 am »
Cappy,
I have all my heat pumps on a separate line. That may help you.
