FS: Arcam FMJ A32 Integrated Amplifier 100W in Great Cond w Phono and OEM Remote
0 Members and 1 Guest are viewing this topic. Read 161 times.
dvzzz
Price is $550 shipped in cont. USA.
This is the most coveted Arcam amplifier by many who are Arcam loyal, I have owned most of Arcam top integratedes starting with Alpha 10, this is my favorite sonically and from the setup perspective. I have way too many Arcams in my collection.
Many agree that Phono stage on A32 is besting some of the more expensive British phonos of the era. They are built like tanks (FMJ series).
Everything works, I have videos that I can send you showing how it powers, and that display works.
100wpc Integrated Current Feedback Amplifier
Ultra wide band power amplifier
Studio grade electronic volume control
Menu driven advanced control system
SDS resonance damped chassis
MM/MC phono stage
Full remote control
Matching P35 Power amplifier for Bi-ampling
Class leading sound quality
There is no question that the A32 set new standards for its class. It is very powerful, producing 100 watts per channel into 8 ohm speakers and 150 watts per channel into 4 ohms . More importantly, this power is delivered with extraordinary subtlety and control. Total harmonic distortion is minute, the dynamic range is huge and the A32 responds to transients in a way that will be the envy of competing models. The result is an amplifier that will enhance any high quality hi-fi system, providing an open and smooth, yet supremely detailed and dynamic sound.
Nevertheless, the appeal of the A32 is not solely its sonic performance and styling. This is not spartan design, and its performance is not achieved at the cost of flexibility or ease of use. The A32 is fully remote controlled and the included handset can also operate the matching FMJ CD player and radio tuners. It comes fitted with a very high quality turntable input suitable for either moving coil or moving magnet cartridges. The A32’s input sensitivity is adjustable for all inputs allowing volume levels to be equalised when switching between source components. It boasts tone controls that can be individually adjusted and remembered for each input. All of these variations, and many more, are easily accessed and controlled using the menu driven display. You can even write your own “welcome message” to greet you each time the A32 is switched on.
In addition, a matching 100 wpc power amplifier was available, which can be used to further enhance the performance of the A32. The P35 power amplifier could be purchased in either 2 channel or 3 channel versions to bi-amplify (or tri-amplify) suitable speaker systems or to provide amplification for multi-channel audio systems.
The A32 was designed and manufactured in the UK, black finish.
« Last Edit: 16 Dec 2025, 07:37 pm by dvzzz »
