FOR SALE:***SOLD*** Reference 3A Royal Virtuoso, Upgraded!
0 Members and 1 Guest are viewing this topic. Read 273 times.
cementhead
Selling up graded 3A Royal Virtuoso. 1700 dollars. HEAVY Corian cabinets w-beryllium tweeter. April 2022, these were sent to Tash at Ref 3A for a complete overhaul, they are COMPLETELY UPGRADED with every available option and they sound magnificent. Significantly better than the MM De Capo BE II. Graded at fair due to one of the speaker corners being repaired and a small crack in the corian on the other one. These heavy speakers will ship in the padded factory flight cases. Prefer local audition and sale in CT., as these are big and heavy! Pay Pal F and F, Venmo, or cash,
only. Included: Aluminum flight cases, Audio Sensibility Statement Teflon insulation 6N OCC jumper which matches the internal wiring of the speakers.
Upgrades included.Here’s the work order:
Larger bucking-magnets added to the existing magnets.
Solid Delrin acoustic lenses are installed to the core of the driver magnet.
New set of multiple KPM polypropylene capacitors in parallel, with a Mundorf oil and small Teflon by pass capacitors installed.
This replaces existing old paper in oil capacitors (also excellent but a little too slow for the new beryllium dome tweeters).
Heavy steel tension rods are installed across the cabinet and new more effective acoustic materials added inside.
Gold plated copper binding posts are installed replacing the old connectors.
Beryllium dome tweeters with microfiber textile material clad flanges installed.
New shorting jumpers made of 7Ns pure OCC copper/Teflon conductor will be supplied.
Soft brass screws are used for mounting the drivers.
Rearranged the mechanical grounding of the main drivers to accommodate the bucking magnets.
Special heavy gauge OFC Litz and thiner pure 7Ns copper OCC/Teflon tweeter wires are used to rewire the speakers.
Damaged speaker grill repaired inc new fabric.
And, pretty much as always, I do not know why they are sideways and do not know how to rotate them... :|
« Last Edit: 9 Dec 2025, 09:32 pm by cementhead »
SteveFord
Re: FOR SALE: Reference 3A Royal Virtuoso, Upgraded!
« Reply #1 on: 7 Dec 2025, 03:15 pm »
Are you posting this from a phone?
cementhead
« Reply #2 on: 7 Dec 2025, 05:19 pm »
No sir.
GentleBender
« Reply #3 on: 9 Dec 2025, 10:29 am »
I rotated the photos. GLWS
cementhead
« Reply #4 on: 9 Dec 2025, 12:59 pm »
Thank you, Bender!  :D
