NORTH4 and 2 Guests are viewing this topic. Read 8312 times.
Amazing value for a quad PCM1794 DAC. I'm guessing the Chinese dual discrete OP8802 op amps
What's OP8802 sound characteristics? I have received some inquiries, and before one tries to buy the XiangSheng DAC, make sure to:1. Confirm in writing (explicitly labeled in Ad or in messaging) that the version being ordered has Four PCM1794. 2x1794 version is cheaper. Buy the cheaper version without the front UV meters (why?) and cheaper bluetooth (I took the antenna off). 2. Take into account the current tariff situation. Most of these vendors will state they are "not responsible for duties," so that might be another ~$50 in tariffs to pay once the package arrives in U.S.
In my Douk Audio equipment the OP8802 are warmer with a much larger soundstage than the stock op amps. As to the tariffs, don't believe the statement in the Chinese ads that "import duties are included" or something to that effect. I've had to pay about 25% of the declared value. With DHL, for example, they gave me notice one day before the delivery date to pay the tariffs or the item would be "held" and if not paid eventually sent back to China. If you allow that to happen good luck trying to get a refund!
Yeah, many of these class A discrete opamps will have that warmer sound. I think I'm good with my other class A opamps already. DHL seems to be the main one that emails you to pay duties a day before scheduled delivery. This happened to me recently on some cables, so I paid the duties. However, depending on the specific seller, it is sometimes possible to message the seller on Aliexpress that you want refund on the duties you paid DHL if the seller Ad page stated Price "includes import duties." In my case, the seller actually paid me back the duties I paid DHL through Aliexpress dispute process If your purchase is recent, you might try that.
I have scoured any posts I can looking for the dimensions of the DAC. Only the weight is listed. Can you post a set of measurements of the unit itself? Thx, Jake.
Can I use them in this DAC using this? With a riser?
I just ordered one of these. The total was $257 since AliExpress has discount coupons running right now. The seller says to expect $48 in tariffs. So I'll be right at the $300 price point. I'll drop some OP8802 op amps in it and see how it sounds. Thanks again, Jon.
I just ordered one of these. The total was $257 since AliExpress has discount coupons running right now. The seller says to expect $48 in tariffs. So I'll be right at the $300 price point. I'll drop some OP8802 op amps in it and see how it sounds. Thanks again, Jon.Here is the link: https://www.aliexpress.us/item/3256808785758215.html?spm=a2g0o.order_list.order_list_main.5.2679180252DN0g&gatewayAdapt=glo2usa
Just received my second XiangSheng DAC05AII! It only took 12 days and no one asked to pay any additional tariffs
The build quality with double transformers and quad convertors is remarkable in this price range. With the upgraded op amps and shipping I have about $400 into it.
What opamps are you using? Plan to try the SS2590 pro opamp at all?
