Room Acoustics
0 Members and 1 Guest are viewing this topic. Read 3909 times.
El Tio
Room Acoustics
« on: 2 Dec 2025, 10:46 pm »
Happy Holidays!  During Thanksgiving we had guests staying over. I dragged out a 3" thick memory foam king size mattress topper that we stopped using and put it on the living room floor for the kids to sleep on. After they left, with the topper still on the floor I had a listening session and was amazed at the improvement in soundstage. The floor in this room is tile with a thin throw rug in the center. I knew that it was an acoustic problem but really had no options given it is the family room. I did some research on the type of foam that is used and determined it is closed cell which is not ideal but can improve low frequency. There was no arguing with the improvement it made. I cut the topper in half so I can roll it up and put it away easily but can toss them back in there when I have the house to myself and want to do a long listening session. I stack one on top of the other for 6" thick. At some point I will probably get out the microphone and take a measurement of the room to see if the change is measurable.
System:
Aurender N150 streamer/server
Lampizator Baltic 3 DAC with Cryotone tubes
McIntosh C2600 preamp also with Cryotones
McIntosh MC462 SS amp
McIntosh MPC1500 pwr controller
Spatial M3 Sapphire speakers with custom crossovers. GAIA II isolation
Interconnects: Audioquest and Moon Audio
Speaker Cables: Anticable 3.1 (I love the Bass these bring over more expensive cables)
Pangea Audio Power Cables
Dedicated 20A overspec AC circuit
Various room treatments
mresseguie
Re: Room Acoustics
« Reply #1 on: 3 Dec 2025, 01:31 pm »
Great discovery!
My wife would have a fit if I did this, but I would like to try something similar in my living room.
toocool4
Re: Room Acoustics
« Reply #2 on: 3 Dec 2025, 03:43 pm »
El Tio try using a large area rug and thick underlay underneath it. Not intrusive and I am sure your wife will not mind especially if you choose a rug she approves of.  :thumb:
If you click on my system on the left under my avatar, you will see my room. That is how I deal with the floor.
Cloud.sessions
Re: Room Acoustics
« Reply #3 on: 4 Dec 2025, 06:10 am »
@El Tio
lol I love the craziness. I’ve done similar things in the past two.  :lol:
The floor reflection is actually the most critical in your room as it’s usually close enough in time to the speaker that our brains can’t decorate it as a reflection. We hear that as a smearing of transients and sound stage focus. A similar thing happens if you put your speakers too close to the side walls.
My recommendation is get a good thick rug that does a good job at absorbing sound. I found really good luck with Thomasville Marketplace Luxury Shag Rugs that you can get at Costco and other retailers. They do a great job at absorbing from about 400 Hz and up, and yes, I’ve measured it.  :D
DaveWin88
Re: Room Acoustics
« Reply #4 on: 5 Dec 2025, 01:25 am »
I couldn't agree more on the floor being one of the earliest (4ms) and quite destructive reflection! When that reflection reduced, it's quite shocking! The soundstage and image become even more localized, and the best way to describe it would be. The frontwall becomes like (in visual terms) a large museum diorama. It's crazy guys! The sound stays closer to the speakers. Plus in turn, you can use a bit more volume! I have a "chunky Jute rug that I bought off Amazon. I've had to cut it back a couple of times as it was too effective. Imo, we want to hear the floor to some degree and the ceiling on the frontwall. It give the recordings some sense of "Space and the Ambience of the venue. $250.00 for an 8x10 A great article on rugs.
https://www.acousticsciences.com/whitepapers/acoustic-carpets/
veloceleste
Re: Room Acoustics
« Reply #5 on: 5 Dec 2025, 01:42 pm »
I used this calculator to find first reflection points. There is a bit of measuring and conversion from inches to centimeters involved, but the results seemed to work. To experiment, I placed heavy couch cushions on the floor at the first reflection points and the bass became tighter and had more definition. The area is carpeted so I’m going to leave it alone but I may put some insulation in between the joists at the first reflection points of the suspended ceiling to hear if that makes a difference.
http://
https://www.acoustic.ua/forms/calculator4.en.html
DaveWin88
Re: Room Acoustics
« Reply #6 on: 7 Dec 2025, 08:56 pm »
Plan B is always the next best thing. The reflection point is pretty close to the seating position. It looks like you have a good solution!
El Tio
Re: Room Acoustics
« Reply #7 on: 9 Dec 2025, 01:45 am »
I had another listening session this afternoon for a couple hours. I put one of the pads I cut between me and the speakers. Again I was amazed with the improvement. This has been the biggest improvement I have made to my system in years. My music source is FLAC files on my Aurender Server/Streamer. before when I would listen to a track that had exceptional soundstage/imaging I would add it to a playlist I named Imaging. Now I want to add just about everything I listen to that playlist. Thanks guys for your feedback to my post.
