Preamp tone controls??
usaman
Re: Preamp tone controls??
« Reply #20 on: 26 Nov 2025, 05:02 pm »
First off, I was disappointed they weren't going to have a black friday sale.  Adam said he could have one shipped out now if it was without the new phono option.  I decided to go with the new visionQ+ circuits installed but there are 4 units ahead of me.  Ill send them my external visionQ phono for consignment.
I might add, there is unfortunately only one phono input on the backside.  Its properties need to be selected by removing the cover and choosing the appropriate dip switches. Since I normally use a MM, I do sometimes switch out for a MC and it would be nice to set up the inputs as phono 1 & 2 for a no-fuss quick selection. After all, I'm sure there's a lot of fellas out there that like to switch out their cartridges.  I imagine that would entail a more involved circuit though.
Tone Depth
  • Music Lover
    • SRLPE Wheel Works
« Reply #21 on: 27 Nov 2025, 12:12 am »
An audio friend of mine just turns up his CFR volume control when he wants to hear more treble or bass.
brooklyn
« Reply #22 on: 27 Nov 2025, 02:41 am »
I personally haven't had tone controls in any piece of gear since the early 80's and never felt like they were needed or I was missing something.. I'm old school, I want nothing extra in the signal path.. or the old saying, less is more. I can see were there might be a need for them to augment certain recording or maybe in a less then desirable room setting.. I say if you feel the need, go for it..
peter4jc
  • AVA DVA-M225's & Fet Valve CFR
« Reply #23 on: 27 Nov 2025, 06:12 pm »
Understanding that it'll save some $$$ to have the VisionQ built in, to me it makes more sense to have the phono stage be external, simply for the future possibility of switching it to something else.
toocool4
« Reply #24 on: 27 Nov 2025, 06:27 pm »
Absolutely agree with peter4jc. I’d never choose an internal phono stage or, if I used digital, an internal DAC. It’s far better to add what you need when you actually need it. These components evolve so quickly why lock yourself into something that could already be outdated by the time you come to use it?
« Reply #25 on: 27 Nov 2025, 06:46 pm »
+1.  Correct less is more.
Since the 1990s Hi-Fi equipment has been in constant decline, with only planned obsolescence modifications implemented to increase manufacturers profits. The only advance was Class D amps.
IEC plugs everywhere with a dozen of contact transfers.
Lead-free Euro solder.
Disappearance of Alnico magnets.
Resurgence of perishable formats like vinyl.
Output stages with multiple power transistors.
I.Greyhound Fan
« Reply #26 on: 28 Nov 2025, 01:34 am »
On the other hand, with it being built in, there 2 less RCA cables and a power cable, plus 1 less box.Also, having it built in will make it more value for resale.  He can always upgrade to a better external phono preamp in the future.
I am adjust playing devil's advocate.
peter4jc
« Reply #27 on: 28 Nov 2025, 05:52 pm »
Valid points.  When I put my Vision SLR preamp on consignment with Mary, they had another one w/o the built-in phono and it was selling for ~$200 less, IIRC.
If only we had a crystal ball to tell us what purchase would ultimately be replaced by the next best thing...  when I bought the Vision SLR, I thought it was already a stretch money-wise.  If I'd have just gone all in and bought the Fet Valve CFR in the first place it would've meant spending less than I ultimately did.  Oh well, I'm done now... :icon_surprised:
usaman
« Reply #28 on: 29 Nov 2025, 09:07 pm »
Eliminating the extra box and freeing up a couple of nice morrow ICs, was my consideration for an installed phono circuit.  I'm sure I'll be pleased with the improvements of both the preamp and new VisionQ+ phono.  Both of them will probably be my last upgrade.  My only decision is how I'm going to get the M225 monoblocks in my house without my wife frowning.  When I muster that courage, Ill be content for many years to come.
peter4jc
« Reply #29 on: 29 Nov 2025, 10:31 pm »
That combo of the Fet Valve CFR and the M225's is hard to beat!
