NP1
1965
NP1
« on: 1 Nov 2025, 01:36 am »
  Almost 6 years ago I called and as every other time, Frank answered my question……If you were to upgrade my amp(Omegastar 240), or one of my preamps(Omegastar EC when changing tubes in the T7) which would you replace? “Oh, most certainly the amp!, our SET120 is the ticket”. Being me, tightwad extraordinaire I did not. I certainly took note when after a somewhat short lifespan, the SET120 was replaced with the NP1. It had to be good for Frank to do so.
    I’m regularly on eBay looking for vintage Signature Grados and popped up a NP1 in my state less than a year old. “Moving to tubes” was the response when I enquired why the sale, so I bought it.
     I love love love this amp. I saw the comments about a slight forward or brightness,….not here. And this is where This won’t be much help to those looking for comparisons. I run 2 sets of DIY bookshelf style alternately. SB acoustics drivers in both with different tweeters. But what I’m hearing from the NP1 is more clarity and articulateness across the board. Bass, mids, and treble. All three. It’s not a fair fight with the old Omegastar which I thought was a great sounding SS amp…….I liked it better than my Nelson Pass designed Forte 3. The Omegastar in comparison is smoother, so I guess if your ancillaries tend to bright the NP1 might be too much of good thing but with the T7 feeding the NP1 it sounds like heaven.
  Sorry for what some may consider a lengthy post.
I.Greyhound Fan
Re: NP1
« Reply #1 on: 1 Nov 2025, 02:51 am »
It is a great a great sounding amp.  I loved doing the review for Frank.  I actually prefer the warm, romantic midrange tone of the SET amps but the NP1 has a wider sound stage and more transparency.
1965
Re: NP1
« Reply #2 on: 1 Nov 2025, 02:52 pm »
I would guess the Omegastar and SET sound more alike than different as well. So if I get tired of the NP1 I’ll re-insert the 240. Soundstage between the 2 is very similar.
YungestMarco
Re: NP1
« Reply #3 on: 7 Nov 2025, 01:25 am »
The NP1 is the amp I listen to the most and while I've also heard some say it is a little bright/forward, when I first got it, it sounded like the treble was a bit recessed with my system.
After a week or 2 of burn-in, it sounded very neutral and transparent. It pairs perfectly with the Fet Valve CFR and am running some sylvania gold brand 5814a's and RCA blackplate 12at7 tubes
lepharaon33
Re: NP1
« Reply #4 on: 7 Nov 2025, 06:22 am »
Awesome find — the NP1 really is a step up. Frank nailed the clarity without losing musicality. Sounds like your setup and T7 pairing are spot-on; that combo’s hard to beat for detail and balance.
