Requested : Details/Manufacturer Mains Switch Bryston 2B -LP
REDGUUZ
Hi,
I am in the process of overhauling  a Bryston 2B -LP ca. 1990 Serial  207634 , Main Amp.
(In one channel,  one of the supply line capacitors (ROE 4700 uF, 50V, 105 deg C) had deteriorated.
Replaced all those 4 ROE's Supply line capacitors (2 in each channel)  and 6x 470 uF Nippon Chemicon 470 uF 16V 105 deg.C. electrolytic Caps.
However, in the process, unfortunately I damaged the Power Switch.
Can you please provide me with the Details (Type/manufacurer/etc.) of this mains/power switch ? and possibly a source where to purchase it.
Also (if possible) , I would like to order one full set of black Robertson screws which retain the lid and the front heatsinks, in order to fully tidy up this amp.
I believe this  AMP was reviously used in an IMAX movie theatre in Rotterdam, Holland, but it has survived very well.
I would really appreciate your help!
Kind regards,
Martin (the Netherlands).
  • The Demo is Everything!
    • http://www.bryston.com
Re: Requested : Details/Manufacturer Mains Switch Bryston 2B -LP
« Reply #1 on: 27 Oct 2025, 10:35 pm »
Hi Martin - please email Mike - [email protected]
REDGUUZ
« Reply #2 on: 28 Oct 2025, 08:17 am »
Hi James,
Thank you very much for the help.
Martin
REDGUUZ
Hi Forum,
Very happy to report that the Dutch Importer MAFICO has sent me a complete Power Switch for a Bryston 2-LP.
Alway very fine service from this importer.
(I have 2 Bryston 2 LP's (resp 1991 and 1993), which were originally used by the Dutch Radio NOS 1.
Although they were still 100% functioning (after some - 35 years), I have now recapped them, just to be sure).
Amazing quality and service, these Bryston AMPs !
GrooveControl
... I have now recapped them, just to be sure)...
Hi REDGUUZ, did you re-bias the amp after changing the caps? and if so, can you share the procedure for this?
I see the test point in the top right corner, and the adj pot near the top centre.  Are these what we use, and what value are we aiming for?
Thanks in advance.
REDGUUZ
Hi Groovecontrol,
You apparently have the same vintage (1993) Amp as the one (of he two) Serial #207634, which I recapped (Photo 1 and 2).
I judge this from the PCB Marking (April 90) and the Black ROE EYF 4700uF 50V 105 deg. C power rail caps.
(My other Bryston 2-LP (1991), Serial #205958, has Gold coloured ROE's, same form factor,  but is otherwise identical to the newer amp.
You have the professional version, which has a volume control, bot otherwise the PCB is identical.
1)
I did NOT touch the Bias setting, because this is NOT required if you haven't replaced the SJ6521A  /SJ 6522A Power transistors and/or the drivers (SJ1490/1491).
When recapping a fully working Bryston 2B-LP amp (as in my case), you do  NOT have to reset the bias (leave well alone!).
2)
Also, I  did NOT replace the dodgey bias pot by a multiturn Cermet pot.
(I would have done this, if I was repairing a blown amp).
If you do not touch the old pot, I think it will hold on, but if you are planning to readjust the bias, it is almost imperative to replace it.
If the wiper of the old pot  opens  up temporarily whilst adjusting, you will blow your power transistors.
3)
If you would replace this bias pot I would advise to first determine the setting by measuring (with an Ohm meter), the resistance between the wiper and each of the ends.
Next, I would reset the new (multiturn cermet) pot such that it hase the same reading between the wiper and the ends.
4)
The procedure for setting the Bias is explained in Bryston's service sheet for the older (but almost electrically identical) Bryston 2B.
See attachment 3 for the procedure and attachment 4 for the correct schematic.
This file used to be on their website, but I cannot locate it anymore (I assume it is public though).
John Tullet has alaso provided a very detailed narrative on setting the Bias on a Bryston 2B :
https://www.audiocircle.com/index.php?topic=184949.msg1940311#msg1940311
5) Recommended Bias setting
The recommended bias setting (aged components and temperature stabilised) is 10 - 12 mV, measured across the green 0.15 Ohm power resistor next to TP1.
I would advise to make dedicated plug  + wires (which fit  on TP1) and hook up these wires to your DMM (in mV setting DC).
6) "Recapping"
Imperative:
2X ROE EYF 4700uF 50V 105 deg C by Nichicon 6800 uF 50V 105 deg C (Diameter 35m Height 32 mm).
Resistor for LED : 2K7 1/2W  to be replaced by 2K7  3W  Metal Film resistor :  Your one is already partially fried!!
Optional:
3X Chemiccon KME 470 uF 16V 105 deg.C by  Nichicon UKA 470 uF 35V 105 deg C or Panasonic FC 470 uF 35V 105 deg C
3x Tantalum KEMET 1.5 uF 35V by film capacitor WIMA MKS2 1.5 uF 63V
The tantalum caps have 50% safety factor (35V vs 24V  rail voltage), but KEMET nowaday prescribes much higher safety factors : 2-3 Times the rail voltage!!
I replaced these tantalums , just to be sure!
The Nichicon's  ( 470uF 16V) were still OK, the ROE's (4700 uF 50V) were definitely failing (bulged) and will then leak out a nasty electrolyte.
I hope that this has answered you questions.
I like these little amps and I am very happy with them and Bryston's excellent service.
GrooveControl
I appreciate you taking the time to provide all this info. This is very useful.  Thank you.
This is the third time I own this amp.  The first two were from the 80s and had the older transformers the hummed like crazy so I sold those.  But I’m keeping this one! Mine has the headphone jack and is fantastic at driving my middle range headphones.
Yep, can’t say enough about Bryston’s service too. Top notch.
Now, off to order some parts…
Cheers
REDGUUZ
Hi GrooveControl,
You're welcome!
Forgot to mention:
If you can borrow or own a variable mains auto-transformer (AKA Variac) , it is a good practice to start up one channel of the overhauled amp , whilst monitoring the speaker outlet for off set ( DMM in DC mV setting).
Slowly increase the "mains voltage" from zero volts by slowly turning the Variac to your nominal voltage.
I live in a 230V country: at approx 145 V AC, the yellow relay clicks and  and you get a DC offset reading at your Loudspeaker terminals..
Keep on monitoring this DC offset between the red and black Loudspeaker sockets, whilst slowly increasing the "Mains" voltage to nominal value. (in my case 230 V AC).
 In 120V AC countries, I would expect the yellow relay to click at approx 75V AC mains. Slowly increase to 120 V AC.
The DC Offset should stay below 50 mV.
Install the PCB of the other channel  (amp switched off) and repeat this procedure.
Test the amp with cheap speakers just to be sure that everything is well.
I had a very low offset (resp 2 and 4 mV) in the channels of one Amp: the 1991 model
In the younger 1993 amp this offset was 17 and 15 mV. (both before and after recap).
In these Bryston 2B-LP amps one  cannot adjust the DC offset  to almost zero mV (there is no pot).
Only the SST series received a Pot to fully trim DC offset to zero mV.
Success with your restoration!
Martin
GrooveControl
Thanks again Martin.
I don't have a Variac, but I did use a dim bulb thingy when I restored my Marantz receivers several years back.  I was testing as I went along, every few caps or so.  This 2B will be even easier to work on. I'll only be touching the amp boards, nothing mounted directly to the chassis.
GrooveControl
« Reply #9 on: 31 Jan 2026, 04:16 am »
Well the parts finally arrived today, and I managed to get one side done tonight. Everything went well except for two minor unexpected things… first the holes for the main filter caps needed to be drilled slightly larger for the new caps. Not much, but a little.  Second thing was that I was surprised how easily the trace comes apart from the board where the traces are thin.  Got to be careful there.
I ended up changing the bias pots as well, as one channel had drifted and I was going to be messing with it anyway.  Thanks again Martin for the advice on measuring the setting of the pot in place and replicating that on the new pot before installing. Great tip.
The bias had drifted one one channel quite a bit.  I suspected something was off as one channel felt noticeably warmer than the other.
Left channel 12.6mv and heatsink at 37 degrees Celsius
Right channel 3.4mv and heatsink at 29 degrees Celsius
The WIMA caps I received look larger than Martin’s, and they just fit.   Maybe I ordered higher voltage, I don’t remember. The resistor was larger too.   Speaking of resistors, the old one measured about 6.8k, instead of 2.7k.  The led is now definitely brighter on the channel I completed than on the other.
Tomorrow I’ll do the other channel, then I’ll let it idle for a day and then set the bias one last time.
Cheers
REDGUUZ
« Reply #10 on: 31 Jan 2026, 09:01 am »
Hi GrooveControl,
1) Nice Job!
2) Good that you replaced the wacky Bias Pot. I should have done that as well.
3) You have indeed used some slightly larger components :
Resistor : 2K7 4W  vs. 2K7  2W
WIMA Cap : 1u5  100V  vs. 1u5 63V
But they seem to fit.
4) The Nichicon Caps (6800uF 50V 105 deg.C) have snap in connectors:
Slightly enlarge the existing holes and you could push fit them into place.
But it does not hurt to enlarge the holes. somewhat more.
Succes with the Overhaul of the Second Channel !
Enjooy this nice little Amp!
GrooveControl
« Reply #11 on: 31 Jan 2026, 09:20 pm »
Both channels now running at 10.2mv and 38 degrees celsius.  :D
REDGUUZ
« Reply #12 on: 31 Jan 2026, 11:22 pm »
Hi GrooveControl,
Good Show!!
I also checked the temperature of the Heatsinks (at idle) after 2 hours ( using a K-Type thermocouple and a dedicated Digital Tenpereature "DMM")
 ->37 deg C (@ room temperature = 19.5 deg. C), hence results identical to yours.
I have 2  Bryston 2B-LP amps
DC offset of the older (1991 vintage) one is 3-4 mV
DC offset of the newer (1993 vintage) one 15-19 mV
So well within Bryston's spec's  of  < 50 mV
If I look at the schematic of the SST2, you could retrofit that  particular DC offset adjustment system (2 additional resistors,  one multiturn cermet pot).
But this is not really necessary, IMHO.
I overhauled these two Amps already  2 months ago  (no ïnfant mortality of the new parts observed).
They sound  very nice (I guess you will also love them, since you already used similar ones ages ago!).
Martin
BTW
Is your "Avatar" a Technics SL-150 or SL-1500 Player?
I use a similar one (plus SM_309 Mk2 arm plus B&O MMC20CL cartridge).
Very happy with that player (but it also required a recap: 7 capacitors).
GrooveControl
« Reply #13 on: 1 Feb 2026, 12:43 am »
Hi Martin, I have a pair of Technics SL-1700s. Great turntables.  I think I should recap them too some day.
I’ve been working on a Technics SL-1400 mk2.  A beautiful piece, but a real pain due to a problematic design of the cueing function. I had to get a part 3D printed! Still not operating perfectly, but I can run it as a manual table if needed.
