0 Members and 1 Guest are viewing this topic. Read 12403 times.
Congratulations.The models with Alnico Woofers have great sound.How much are the sensitivity in this speaker ?
Looks great, how it perform with a small tube amp?
welcome to the altec family. i have a pair of carmels
I have a pair of Altec Flamenco's (almost identical to the Valencia's) in my surround system. They do some things astonishingly well.
which amp and front end are you using?
i also got a pair of 602C but it's just collecting dust since i got the carmel.a few class D amps I tried with altecs didn't sound so good. but then these amps are quite old. so, been sticking to low watt single ended. why haven't you tried the FU19 with A7 yet?
Have you tried to add a supertweeter at all? Adding a supertweeter correctly is turning out not to be a simple matter. I ended up changing crossover points, level, and physical time-alignment further to get nice results without causing side effects. Also, removing the grill helped to "remove the veil."
