Nuprime Stream 9 clicks/pops
Lubo75
« on: 25 Oct 2025, 06:42 am »
Hello everyone,
I own the streamer for a few months now.
When streaming Qobuz, there are clicks, pops.
I have updated the streamer to the latest firmware, but still hear them at different intervals of time.
I am a iOs user and use the Omnia app.
Any ideas of what should fix the issue?.
Many thanks.
rustydoglim
Re: Nuprime Stream 9 clicks/pops
« Reply #1 on: 26 Oct 2025, 03:01 am »
Have you updated to firmware version "4.6.520554" ?
Try to use MConnect instead of Omnia app: https://nuprimeaudio.com/guides/omnia-device-guide/
Lubo75
« Reply #2 on: 29 Oct 2025, 04:38 pm »
Yes, it is uodated to the latest firmware (4.6.520554.52)
Thanks, I will try with MConnect.
Lubo75
« Reply #3 on: 2 Nov 2025, 08:03 am »
I am using MConnect player(not the paid option) as recommended, but still clicks/pops are audible.
Not as often as using the Omnia app.
I can hear them when I move/change for the next song or at the beginning of a song.
rustydoglim
« Reply #4 on: 4 Nov 2025, 08:10 pm »
Is that due to change of sampling rate between the songs ?
There is a Stream 9A for Audirvana Studio Server releasing around end of November (if all goes to plan).  Existing Stream 9 can upgrade to this server if you are a fan of Audirvana.
