Tube power amp under 3k
YungestMarco
« on: 15 Oct 2025, 12:29 am »
Hello all,
After easing into tube gear with a tube preamp, am now looking to purchase a tube power amp.
With sales suspended for VTA ST70s until all current orders are fulfilled, are there any other tube amps (new or used) around or below $3k that are worth looking into?
Re: Tube power amp under 3k
« Reply #1 on: 15 Oct 2025, 12:52 am »
Hello all,
How many Watts do you need?
If you have a low efficiency speaker as 93dB or less use a Class D or GaN-FET power amp, but if you have a 100dB speaker look for a used Decware Rachel or order something with Radu Tarta or Dennis Had.
YungestMarco
« Reply #2 on: 15 Oct 2025, 01:02 am »
If you have a low efficiency speaker as 93dB or less used a Class D or GaN-FET power amp, but if you have a 100dB speaker look for a used Decware Rachel or order something with Radu Tarta or Dennis Had.
Have some 95db efficient speaker so 5 watts or more should be good and definitely considering one of Decware's 6 or 20 watt amps
JakeJ
« Reply #3 on: 15 Oct 2025, 01:44 am »
Used or new?
« Reply #4 on: 15 Oct 2025, 01:58 am »
If you live in a cold area it could works.
YungestMarco
« Reply #5 on: 15 Oct 2025, 03:02 am »
Used or new?
Either work and prefer used gear made within the last 15 years so I don’t have to worry about make any repairs within the next couple of years
mick wolfe
« Reply #7 on: 15 Oct 2025, 03:53 pm »
Check out Kenny Russell at GetDynaco.com
seikosha
« Reply #8 on: 15 Oct 2025, 04:26 pm »
I’d highly recommend any Quicksilver amp.
https://quicksilveraudio.com/
JakeJ
« Reply #9 on: 15 Oct 2025, 10:27 pm »
I did a quick search on US Audio Mart filtering the category by price Min=$2000 and Max=$3000.  91 amps turned up and the choices are dizzying.  But you could do a similar search and then when an amp catches your eye come back to this thread and ask us what we think.  Always happy to help others spend their money!
Alain Arseneault
  • Double A
« Reply #10 on: 15 Oct 2025, 11:28 pm »
mick wolfe
« Reply #11 on: 16 Oct 2025, 03:22 pm »
Good call  :thumb: Mid-Mono's might fit his budget.
Delta77
« Reply #12 on: 16 Oct 2025, 04:43 pm »
I wouldn't mind trying a Dennis Had built amp.
You can find them on Ebay, sold direct from Dennis. Dennis uses the name "radioman731" on Ebay.
I believe he uses the brand (Inspire).
https://www.ebay.com/sch/radioman731/m.html?item=157378258502&rt=nc&_trksid=p4429486.m3561.l170197
Also some used ones on Ebay, (not sure of previous users integrity).
I.Greyhound Fan
« Reply #13 on: 17 Oct 2025, 01:18 am »
Look at some of the Rogue Audio amps.  The Atlas Magnum III is just under $3k.
« Reply #14 on: 17 Oct 2025, 01:37 am »
Hi all.
I hope I am not off context ?
https://wrightaudioarts.com/Royale-SE-Power-Amplifier.html
This was a nice suggestion, they dont use PCBs only point to point wiring but I dont know if it is Hard Wiring or stranded, also the transformers are bigger that Decware and Dennis Had. Now they have a new Mono power amp with two KT88 per channel at high price.
Output power informed is excess of 50Wp/c so it may be UltraLinear Pentode, in Push-Pull Triode would be 15W.
« Last Edit: 17 Oct 2025, 03:54 am by FullRangeMan »
DrMorbius
« Reply #15 on: 14 Dec 2025, 04:22 pm »
I recently acquired the Alan Eaton dual mono type 45 SET amplifier. With your very sensitive speakers you would be amazed at the clarity, richness and huge deep soundstage only a type 45 tube power amp. I was a bit leery from the power output but with sensitive Klipsch Heritage speakers I measured over 101db at 16 feet away from the speakers! It takes a few weeks for Alan to build them when you order them but it’s well worth it. Here’s a shot of mine;
rockadanny
« Reply #16 on: 14 Dec 2025, 05:13 pm »
Check out Mapletree Audio Super Stealth+ monoblocks.
Excellent build quality IME and great value. I have their preamp in my system.
https://www.mapletreeaudio.com
YungestMarco
« Reply #17 on: Yesterday at 11:52 pm »
Ended up finding a pair of 300b monoblocks locally!
They were custom-made by Paul Birkeland
