Community
Non-audio hobbies and interests
The IT Crowd
GentleBender
Computer hard drive wattage draw
Volunteer
I reject your music, and substitute my own.
28 Aug 2025, 10:52 pm »
Anybody know if you replace several computer hard drives with a much bigger bigger ones, is it going to take up much more power supply wattage?
WGH
Volunteer
Mesquite Salk Speakers
Re: Computer hard drive wattage draw
28 Aug 2025, 11:20 pm »
I wouldn't worry about it.
Doublej
Reply #2 on:
28 Aug 2025, 11:46 pm »
Even though the hard drives may be much larger is capacity, depending upon how old the existing drives are, you might go down in wattage.
I.Greyhound Fan
Reply #3 on:
29 Aug 2025, 01:38 am »
You should be fine. Now video cards are a whole nother story.
I have 3x4 TB WD Red HD's and 2x1TB M.2 drives in my computer/music server with a 550watt power supply.
Community
The IT Crowd
GentleBender
