Klipsch RP-600M II Upgrade cross over pic
DaveW_396
« on: 18 Aug 2025, 05:07 pm »
Hi everyone, new to the forum so I cannot search for the answer here.  Does anyone who has installed the GR upgrade to a set of Klipsch RP-600M II have pictures of their x-over?  i am going to start this this week and while not overly complicated looking I am wondering how I fit all those parts in such a tight spot in the back of the cabinet.
DaveW_396
Re: Klipsch RP-600M II Upgrade cross over pic
« Reply #1 on: 25 Aug 2025, 01:48 pm »
O.K. here is my attempt to fit it on the proper form factor to fit in speaker cabinet.
DaveW_396
« Reply #2 on: 25 Aug 2025, 01:55 pm »
there is bracing in the center of the cabinet interior that limits the footprint options of the crossover.  Maybe I should have split it into two sections and had the tweeter crossover section in the front half and the woofer crossover section in the rear half.  Would have been much cleaner that way.
Bill Baker
    • Musica Bella Audio
« Reply #3 on: 25 Aug 2025, 05:44 pm »
I thought only the first series had the upgrades. Is there a different upgrade for the mkII as well?
DaveW_396
« Reply #4 on: 25 Aug 2025, 05:51 pm »
Yes there is a separate kit for the version 2 of these speakers.
