0 Members and 2 Guests are viewing this topic. Read 55167 times.
i've received duelund DC cable from ghent last week.
Impressive for such small amount of money. Laiv uDac, T20, Fosi V3 monos
Yup, it's a great time to be an audiophile (well, was even better before tariffs). What is that box feeding the uDAC via Curious USB cable?
received a pair of Muses02 in parallel.it gets up over 100 degrees f after 5 or so minutes. i am a bit skittish.do i need a fan?
100 degrees Celsius? If so, that's higher than Muses02 maximum operating temp is 85 C although damage will likely not occur until much higher. Even with a fan on it, I would check the temp. If one has to crank up the fan speed with increasing fan noise to keep the temp down, it might not be worth it.
100 degrees F (areheit)
That's 38 C and is perfectly safe operating range per their specs.
Sumptuous mids with good mid high soundstage and detail. However, the highs are missing hence sounds a bit boring when I have the volume set at my usual listening level.
