0 Members and 2 Guests are viewing this topic. Read 484280 times.
David,My initial reaction to the B200 was that the claimed 96 db @ 1 watt seemed inflated. But then I simultaneously ran a Jordan JX92S along side The JX92S is rated 88 db @ 1 watt. The B200 plays much louder at the same given volume. Not having a SPL meter makes it impossible to verify what the difference is, but let's just say that it is very substantial.
The Augies have landed. Been here just a day. Have set them up on a very minimal flat baffle as have a very minimal room of 11.5' x 26.5' , and want to avoid room gain as much as possible. Narrow room but length makes it pretty decent. Anyway, plenty of bass, no problem there. Have run them up a little past 300hz and the clarity is good. Enough so that I feel confident can xo to small Fostex and other low xmax drivers in OB above Augies. So far have hooked up Fostex FE107e, Coral 103a holey back, low end ...
