0 Members and 1 Guest are viewing this topic. Read 485383 times.
That's the kind of result I was cautioning against when I disputed Dan's post about the B200 handling plenty of power.
Regarding the spider, it has more than enough travel so no concerns are warranted there. And the phase plug does not create a heat issue as it fits inside the chamber leaving a gap of about one millimeter around the perimeter for ventilation and unimpeded movement of the VC.
