Hi, I have used for around 30hrs, so yes, more break in is need.I don't mean the b200 doesn't sound good, but I believe that is room for improvement. I see that there is a relevant thread in the OB circle, so I am going to move over there.
I'm going to build my first OB's.B200's are on the way and I have some questions: 1) Best way to break in these drivers, special cd's etc?2) Best way to connnect the speaker wires to the driver?3) Good cheap speaker wire? Home depot?4) Where to buy parts for BSC circuit?Did I forget anything?ThanksJohn
Hi Everybody,My name is Rafal and I'm new here. I've been reading this thread over the last few weeks and I am building Visaton B200 OB's over christmass. The drivers are ordered and I'm just finishing the Charlize amp (I used to have a LM3875 gainclone but I fried it good). I have played with OBs before. You can see my experiments with FR125s in OB here: http://www.diyaudio.com/forums/showthread.php?s=&threadid=74972&highlight=When I listened to OB I had quiet the epjifany (sp?). Similar to the time when I realized how much better an active system sounded over passive (in that case it was Linn).I will likely stard building something simillar to Vinnie's (from Red Wine Audio) and I may experiment with curved or acrylic wings I also plan to install a "shelf" over the driver at the back of it. I just hope I get enough bass that I won't need a sub .Cheers,Rafal
Using a baffle step compensation circuit, as discussed, might help you get the sound you want without a sub.
