Gravity Well Of A DarkStar
0 Members and 2 Guests are viewing this topic. Read 484286 times.
-Richard-
Re: Gravity Well Of A DarkStar
« Reply #1040 on: 24 Aug 2006, 03:56 pm »
Some of the Jamo's are certainly well executed designs and they may benefit from good
engineering as well... however their price tag is around $13,000!!!
Many of us who are contributing on this thread and who are working with their own designs
have spent far less than $500 in total for all the elements of their Open Baffles...
certainly not much more than $1000. ~
Sooner or later, speaker designers seeing a growing audience for OB designs will begin
to offer "classy" versions of what we are doing ourselves... but for far more money than
any of us would care to spend ~
Fashion design seems to work that way as well... the "classy" clothes designers take note of what
the most innovative young people are wearing and then copy it... the thrown together clothes
combinations that these young people spent practically nothing on are then seen reflected
in the "hip" clothing stores for hundreds of dollars ~
Once anyone reading this thread begins to work with drivers like the B200's and simple
Open Baffle wood panel configurations your paradigm of what is possible in realistic music
reproduction will undergo a major reassessment... for me it was nothing less than
a revolution in my thinking about audio!!!
Warm Regards ~ Richard ~
scorpion
« Reply #1041 on: 24 Aug 2006, 04:11 pm »
JohninCR,
Glad you are back here with us. One of my boys was in Costa Rica for 1 month this summer had I been more observable I would have liked him to visit you, if that could have been arranged. But I do not think that he is so much interested in my speaker DIYs although his has 'inherited' some of my very good equipment and speakers down the road.
As you know also the  kidboys in the Islamistic Koran Schools also believe wholeheartedly in what they hear with their ears are the truth. But that doesn't mean that one should be too affirmative. I would say that level bass down to 40 Hz would cover 99.9 %  of recordings of instrumental music that can be bought in the market.
/Erling
« Last Edit: 24 Aug 2006, 04:24 pm by scorpion »
Wind Chaser
« Reply #1042 on: 24 Aug 2006, 04:26 pm »
Greetings all,
Some of you know me from other forums, some of you may not. I have been reading this thread almost from the start, but have refrained from posting because I don’t own a B200, nor have I yet heard one. I decided to jump in now because of the above statement about the Augies having  “slow and muddy” bass.
I own a pair of Augies and have heard them in another system as well. The bass is both clean and extended as any bass I have heard in a sound system in my entire life. It allows bass down to 30 Hz on a modest sized baffle, and does it very clean with no boom, muddiness or other bad effects. It is now developing a strong following on it’s own for having astonishingly clean and open bass.
I would suggest that if anyone is having a problem with muddy bass using the Augies as a bass augmenter, there is something very wrong. Either the room has a serious problem, or the Augies was not hooked up properly, or the associated equipment has a compatibility problem. One has to be sure there is little overlap of the Augies response range and the main driver. This is true of almost any bass augmenter. The Augie is intended to supply bass below where the main driver rolls off or is restricted by the crossover. If this is not done right, muddy bass could result. Not the Augies fault, though.
BTW, the Augies are intended to be run from a separate amp in a biamped fashion. If they are hooked up in a passive way to the main amp, I don’t know how this would sound. I suspect it would be, to a large extent, depending on the amp’s ability to damp the speaker with a large inductor in the path. This might cause some muddiness. This would be the amp/inductors fault, not the Augies.
Hi Dave,
Nice to see you in these parts…  My comments about the Augie are in the context of the B200 in my system.  Those remarks are not an emphatic statement in the absolute sense that the Augies are bad or even mediocre, but that I found the quality of bass from the B200 to be superior, as in cleaner and faster.  When I had the Augies, each had a dedicated plate amp.  I checked and rechecked the polarity, tried every conceivable crossover point and painstakingly played with the levels but couldn’t get them work favorably with the B200.   I suspect that the laws of physics render it impossible for a 15” driver to respond with the same alacrity and agility as the B200.
John
Wind Chaser
« Reply #1043 on: 24 Aug 2006, 04:46 pm »
Dave,
I'm with you, but once again his loss is my gain.  I picked up a pair of B200's
from him (before his change in religion) and that pair of Augie's too...
John,
There was a time when I limited my understanding to the eloquence of your theoretical beliefs and nay saying.  But then I took it upon myself to do the most rational of all things... experiment for myself.  This change of religion was for the better.
John, seriously I don't have an axe to grind.  I just find that some of the things a few people have said here to be quite to the contrary of what in reality has been my experience.  Peace!
John.
« Last Edit: 24 Aug 2006, 06:22 pm by Wind Chaser »
scorpion
« Reply #1044 on: 24 Aug 2006, 08:56 pm »
I am all too happy !
Some of you might have seen me too blasphemous or arrogant and quickjoking,, well, I am a big fan of Monty Python ! And if going out in
Jihad one should have at least one commandment, wherever it comes from.
John, the link is: http://www.pollin.de/shop/shop.php?cf=detail.php&pg=OA==&a=MDQ1OTUzOTk=&w=Nzk3OTg5&ts=40 only in German I think. I have been searching around and I think that X-max could be anything from +-2 mms to +- 3.5 mms. Probably the elements
are manufactured in Checkia.
I have been checking this link out. It does not lead you right. When going there, take zuruck (almost the same in German), then page 4 and Westra KW 200-1316, that is the element. The Qts I have obtained from another German source selling the same element at the going price.
It does not appear in the current 2006-2007 Westra Catalogue.
/Erling
« Last Edit: 24 Aug 2006, 10:08 pm by scorpion »
JohninCR
« Reply #1045 on: 24 Aug 2006, 10:11 pm »
Scorpion,
I like the little dual voice coil 6.5" at the bottom of page 4.  It looks quite robust and
the extra VC allows you to dial in the desired driver Qts.  8 to 12 of those per side
would make really versatile, solid output, small form bass augmenters that could be
integrated with any full range driver.
Ever since I built a pair of W/U baffle hybrid subs using four 12's per side using the
Ripole small pathway approach, I've wanted to build something similar with smaller
drivers and an interchangeable plate on top to accomodate any full ranger in a small
baffle.  The result would be a fully OB mini-tower with great bass performance.  A DVC
lower priced version of Tangband's 6x9 sub driver would be absolutely perfect with
its 7mm Xmax and compact stacking of 6x9's
scorpion
« Reply #1046 on: 24 Aug 2006, 10:34 pm »
JohninCR,
It seems all good things come from Germany ! I do think Pollin will respond to questions made in English and provide an answer
if they have them at hand. I have found them good to deal with.
/Erling
scorpion
« Reply #1047 on: 24 Aug 2006, 10:45 pm »
JohninCr,
Which Tangband driver are you referring to ?
Now I have read your statements through. Indeed we are working quite in the same direction of
constructing something like the 'ultimate' affordable OB-speaker. If we ever will come there.
/Erling
« Last Edit: 24 Aug 2006, 11:10 pm by scorpion »
JohninCR
« Reply #1048 on: 24 Aug 2006, 11:22 pm »
Imagine how closely you can stack the Sd on these, big open frames too, just a bit pricey.
http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=264-837
scorpion
« Reply #1049 on: 24 Aug 2006, 11:42 pm »
JohninCR,
True, but you will probably require equalization boost for the wanted bass response.
I would like to see how far  I can go without boosting.
/Erling
JohninCR
« Reply #1050 on: 25 Aug 2006, 12:08 am »
JohninCR,
/Erling
That's why I said DVC model, and while I'm changing it I'd like a shallower mounting
depth too to maintain a narrow cab.  I bought a pair of cheapie 6x9's locally that I
can get in volume.  I need to test them before I buy the other 7 pairs, mainly to
determine Xmax and see what they sound like from 300hz down.
Rocket_Ronny
    • ScriptureSongs.com
« Reply #1051 on: 25 Aug 2006, 01:25 am »
Seeing as how Wind Chaser dragged me into this thread by talking about my back loaded Fostex horns, see them here at http://www.scripturesongs.com/audio2.htm, and for more fun http://www.scripturesongs.com/audio.htm, I might as well enter the fray.
John brought over the B200's he's been ga ga over and some winged baffles. We did a quick shoot out between speakers.
I always belly ached about the frequency response of the B200's to him and he would always say they don't sound like that. The Fostex 126 in my horns have a much better response on paper, this is due to Madisound testing the response of the driver mounted on a door in their anaconic chamber while I believe, but am not 100% shure the B200 is tested in a anaconic chamber without a baffle. So the Fostex has a huge advantage by being on a large, and I mean very large, baffle.
So the B200 kills the Fostex 126 in the horn for having a much better frequency response in my room. The horn sound thin and bright by comparison. We were just going off my CD player and I am not corner loading the speakers.  Now I wish I had played the horns for John running off of my Powerbook laptop on I-tunes. There I add about 3-5 db of gain from 1 khz down to 100 hz where the sub takes over. This changes things big time and makes the un-e.qed horns sound unlistenable.
I did not find the B200's in the winged baffle bright, or sounding anything like the frequency plot. It sounded very, very, nice with an amazing amount of clean bass for a full range driver.
I find the horns to image way better than the B200's in the winged baffle. This is no surprise to me however as I am a firm believer in the detremental effects of baffle bounce on imaging. John has stated that he feels that the B200's in his current unwinged baffles images better than the horns. This I do not believe due to all my experience with baffel bounce.
The Fostex 126 is a 4" driver so the sound coming off this small vibrating driver has way less baffle bounce compared to the B200. Going the next step to very large coax drivers introduces much more baffle bounce effect.
This is heard by instrements getting larger in size and more forward overall the more the baffle bounce introduced.
So where does this leave me. I am not going to jump on the B200 bandwagon at this time since I have Sy-Klopz to build. This will be a biamped combination of the Fostex 126 frunning full range coupled with a 8" Seas aluminum woofer as used the Jeseph Audio Pearls - $20,000.00 beans I believe.
I am not worried about having the "unboxed" sound as I have lived with that sound for many years by owing 2 pairs of Acoustats, Maggies, and Apogees. I don't find the fostex 126 horn to sound boxy to me. What I get is a wonderful 3-D landscape of music, completely seperated from the box.
Rocket_un plugged_Ronny
« Last Edit: 25 Aug 2006, 04:09 pm by Rocket_Ronny »
JohninCR
« Reply #1052 on: 25 Aug 2006, 06:00 am »
I'll make this the last counterpoint I'll make in this thread, although I may
remain active to introduce new findings and/or discuss new ideas with
willing participants.  Note that the only reason I do so now is for the silent
majority, as this thread has become a reference of sorts for OB's using full
or wide range drivers.
Ronny,  I'm green with envy at your current room.  If I could build OB's for
it, the rest of my family would be confined to the "little room" if they didn't
like what I'm listening to at the time.  Please keep in mind that, to me, the
thing that separates OB's using dynamic drivers vs ESL's and planar speakers
is the word dynamic itself.  Sounding open is one thing, but open, dynamic,
and natural is a very different animal.  Imagine the imaging, resolution and
dynamics of your little horns combined with the big open sound you've had
before.
You lost me with the "baffle bounce" concept.  If it's the result of reflections
of sound off of the front of speakers with large front baffles, then I concur.
Your description of forward sounding instruments left me with a question mark,
because I think the recording should dictate the orientation of the musicians
and instruments.  ie  When the vocalist is out front, I want to hear it, and when
the lead guitar goes into his solo, I want to hear him out front.
Let's settle this B200 response thing once and for all.  Of course Visaton doesn't
measure their drivers in free space.  Any manufacturer would be insane to do so.
The generally accepted method is anechoic using an infinite baffle, although
those less scrupulous may incorporate a box behind the baffle to inflate the bass
response.  Minor differences between reputable manufacturers can result from
some measuring their 1m distance from the cone vs from the baffle.  What this
means to OBers is that we can look at the response graphs provided by their
makers and know what to expect from a driver on OB before the effects of the
rear wave and room.  Here's what Visaton says the B200 will do, and it's obviously
not in their best interest to understate bass response:
A reasonable person, who's done any research regarding OB's, knows that OB's
have the rear wave in play which cancels bass, not re-enforces it, however, I'll
admit that baffle dimensions, floor gain, and placement can potentially result in a
very slight improvement in bass response over infinite baffle anechoic response,
but it's not easy and requires significant planning.  Because a driver has decreased
HF output from the rear, an OB alignment can result in an increase in the midrange
and upper bass response compared to IB.  Again this is dependent upon baffle
dimensions, placement, and HF attenuation from the rear wave.  The bottom line
is, however, the graph above is pretty much what to expect from a B200 on OB.
The reasons that the information above doesn't contradict the seemingly outlandish
claims made by some regarding the B200 are:  1.  As reflected in Visaton's graph,
the bass response rolloff is very gradual and quite extended.  2.  The requirement
of bass extension is very dependent upon musical taste.  3.  #2 above makes a
great many speakers quite acceptable and popular despite bass that rolls off
steeply below 50 or 60hz, or even in some cases 80-90hz.  4. Last but not least,
our ear/brain combo quickly adjusts help fill in the bass region, and there are even
software solutions that exploit this phenomenon such as MaxxBass.  They amplify
the higher harmonics of fundamental bass notes, resulting in the perception of the
actual bass notes being produced even though they aren't.
Let's take Ronny as a perfect example of #3, and for example's sake we'll make the
optimistic assumption that John's baffle and placement resulted in bass equal to
Visaton's IB response.  Now we have Ronny with a 50hz corner horn that is well out
into the room, so without a corner or even wall support, it would be generous to
say that he's getting a steep roll-off below 70hz from his horns.  That's why he
likes to EQ in a little more bass, despite the fact that his music is probably light on
deep bass content.  What do you think will be the result of a comparison of his
horns (without EQ) to the OB B200, which has gradual rolloff down well below 50hz
which Visaton's graph shows?  Of course the OB will sound like it has more bass,
because it does.
What does this mean?  For those who prefer music without a lot of bottom end content,
at least at first, they can be quite content with the midrange seduction of just a B200
on a simple baffle.  As the evolution of this thread bears out, they will eventually start
to look for bass augmentation solutions.  Even those of us with wide ranging musical
tastes can easily fall under the spell of these sirens, with the result being that we quickly
focus our listening time to musical selections that sound outstanding in this setup, and
ignore the majority of our collection.
I don't bring these things up to slam the B200, or any OB's exhibiting a similar response.  I
bring them up because the claims made by Wind Chaser and others can be very misleading
to those new to the game.  The higher the expectations, the more likely a noob will not be
happy with early results, and just write off OB's as a bad idea.  In reality I'm not the B200
infidel, but actually the outspoken but moderate Ayatollah OB trying to help OB's take over
audio.  Give people reasonable expectations, and deliver them fully.  Then eveyone's happier.
« Last Edit: 25 Aug 2006, 06:17 am by JohninCR »
Polarbear
« Reply #1053 on: 25 Aug 2006, 07:06 am »
Hi John
How do you like your Ripole's? How do you think they preform against an ordinary w-baffle/ plain baffle?
Cheers
Bjørn
scorpion
« Reply #1054 on: 25 Aug 2006, 12:14 pm »
Hi Björn and all others,
Nice to have you around Björn. You should be able to comment about the Bastani Prometheus and those felt applications and also about
monopole vs dipole bass.
Myself I am about to build permanent baffles for the B200s. They have been playing in test baffles quite a long time now and for the moment I think they are the best FRs I have heard. I have not tested or even heard the Omnes L8s but I might buy a pair of those just out of sheer curiosity. The Ciare 250 I still have and like but they are a tiny bit more coloured then the B200s.
My last concern with the B200s is to take down the somewhat 'screaming' high violin notes in playing the full Symphony Orchestra. Now that is an almost impossible task with any speaker and you have to compromise in the end. My hope is that an ingenious BFC circuit will do the job together with a well calculated Zobel network. Now this is not the going BFC circuit that has to do with baffle step correction but one that is aiming precisely at the frequency rise between 1000 and 2000 Hz. In general I do not like components in the signal path and the Ciares I cured with notch filters not in the signal path, but with the B200 I think I have to compromise.
I have been citing German DIY magazines mesurements of the B200. I should also have said the the 'Hobby Hi-Fi' measurement clearly states Infinte Baffle response. This magazine also concludes that with the support of something like 45 cm baffle width the B200 could do even without frequency alteration in an OB. Let alone they would do need bass support. I do not quite agree but it is a valid opinion. Hobby Hi-Fi has presented 3 different Ciare 250 designs in their latest numbers, one OB and 2 KUs. Iwill not go into explanation of what KUs are. They are something in between closed boxes and bassreflex boxes. But just putting forward the Ciares like this and explain their sonic virtuosos is a sign as good as anything else.
'Please keep in mind that, to me, the thing that separates OB's using dynamic drivers vs ESL's and planar speakers
is the word dynamic itself.' I agree wholeheartedly. Having experience from all three of those speaker designs, I'll say:
It is just more fun !
/Erling
« Last Edit: 25 Aug 2006, 02:30 pm by scorpion »
JohninCR
« Reply #1055 on: 25 Aug 2006, 02:45 pm »
Hi John
Cheers
Bjørn
Bjorn,
Welcome to the thread.  I hesitate to call them Ripole's with a front pathway CSA of 645sqcm vs an Sd of about 2,200sqcm, a driver baffle layout like a double stacked Linkwitz dipole woofer, and a cab that extends an extra 20cm toward the rear to obtain some U-baffle behavior.  Despite the differences, I do pick up some key Ripole advantages, small size (4 12"ers in a 12"w x 25"h front) and a lowered Fs by about 15%.  This comes at a cost of a significant loss in efficiency, but with any kind of OB sub the limiting factor is always excursion in terms of max spl at the bottom, which remains unchanged regardless of the alignment.  The W type alignment gives me vibration cancellation, a crutial advantage over Ripole.  The U-baffle form is also another key advantage in-room, because extension isn't room limited like with a dipole.
That being said, these cabs provide the most extended uncorrected bass of any OB I've heard.  The drawbacks are: 1. The distance to the wall behind the listening position has a tremendous effect on response due to it being the single primary reflection point.  2. Any manifold alignment is inherently limited in high end response compared to a fully exposed driver, and you must consider cavity and 1/4 resonances.
A hint to those wanting to implement a Ripole type approach to limit size:  Using thicker wood for your driver mounting baffle actually results in a narrower overall cab.  I didn't realize this until afterward, and I could have shaved about an inch off of my total width.
Scorpion,
Something you have to consider is the efficiency loss in a manifold alignment.  If you don't plan to biamp, the more you narrow your manifold below Sd, the more you cancel the efficiency gain of multiple drivers.  I don't think it's something easily predicted, so test baffles are mandatory unless you biamp.
scorpion
« Reply #1056 on: 25 Aug 2006, 03:13 pm »
JohninCr,
Good point. But not bi-amping does not mean not interfering with the frequency response. I have some box in mind between the source and the amplifier to do the job !
/Erling
« Last Edit: 25 Aug 2006, 03:27 pm by scorpion »
-Richard-
« Reply #1057 on: 25 Aug 2006, 03:47 pm »
Hi Scorpion ~
Both Vinnie Rossi's new Signature 30 and Roger Modjeski's new RM 245.1/45 SET tube amps
resolve quite gracefully any potentially glaring upper frequency instrumental material ~
Both of these amps with my OB's allow violins, for example, to perform with an exquisite
silky delicately nuanced yet dynamic presence that is thrilling to listen to ~
It could very well be an amplifier synergy issue going on in your system ~
JohninCR
« Reply #1058 on: 25 Aug 2006, 04:39 pm »
Scorpion,
I was thinking more in terms of matching sensitivity with the main driver.
So far my approach has been to eliminate as much as possible in the signal
path by shaping response with my baffles.  I've done that with my most
used setup, an FE108 + Hawthorne coax (woofer only) with only a coil and
an Lpad on the woofer in my OB-RLH, and it's quite flat down to 27hz at
my listening position.  It's just a little too big for my relatively narrow 11ft
wide room.
My B200 OB-RLH works very well, quite flat into the 40's.  I'm hoping that
the phase plugs will eliminate the few db of sizzle in the critical range at
the top end.  I did have to sacrifice a lot of OB openess to get the RLH
portion to kick in, but they're still much more "open" than a box and have
great single point source sound.  Once I finish the very thick big roundover
add-on baffles, which should balance the tonality a bit more and cure the
edge diffraction issues, they should image on par with anything.
I've been procrastinating about building new cabs or trying to optimize
these alignments in hope that the new drivers DMason has hinted about
will better fill my needs.
Rocket_Ronny
« Reply #1059 on: 25 Aug 2006, 04:49 pm »
Hey JohnnyCR:
Maybe I missed this in this thread but can you explain the difference you are hearing between the Fostex drivers you have and the B200's?
What I meant by free space was in a anaconic chamber without the baffle. I was in a hurry when I wrote that and have since changed the comment.
With winged baffles they do not sound at all like the frequency plot to me. The balance is very good. Only they do not image as well as I would like. John says with out the wings they are way better. I believe that. But the 4" fostex will still do better I believe.
Baffle bounce has to do with the wave launch of the sound from the driver. The wider the baffle, or speaker for that matter, the more the sound bounces along the surface. This results in images being bigger and more forward.
The NewForm Reaserch 645's are a revelation in this area as everything from 1 khz on up comes off of the very narrow ribbon. The 4" Fostex in my narrow baffle horns comes to about 90% of the NewForms in the imaging department. The 6" fostex 167s would be about 80% and a 8" driver would take another step back.
Still, the B200's are very nice all around and I may end up picking up a pair to play with. I would use a vey narrow baffle, e.q., and a sub.
The room you saw is killer. I was making a smaller room but it could not compete with the big one at all. We since sold that house which I built, hard to leave on acount of that,  and now have a smaller room of 26' by 14'. Still, the older room was better. Space, it is the final frontier in audio. Small rooms just kill the experience for me.
My motto is, "Your room is everything, use it well".
Rocket_Ronny
