Nigel, are you using the 12's at all now? Are the B200's getting down to 70hz at least? That's my current xo for sub.Also on the general OB idea, adding 4" deep sides doesn't hurt the sound at all in my experience, for these larger baffles like mcgsxr is using maybe 6" even (maybe worth an experiment). The point is you can keep the same width as a flat baffle by bending it, as the edge is the same distance away. Too deep sides give them selves away with a detectable cavity resonance. Also one of mine us ...
